ARC LENGTH DIMENSION
All  1  2-5
11229.2 In reply to 11229.1
Hi Alex, try this - put in this script on a shortcut key:
script: /* Update angular dimension to arc length */ var crv_list = moi.geometryDatabase.getSelectedObjects().getCurves(); if ( crv_list.length == 1 ) { var dim_list = moi.geometryDatabase.getObjects().getAnnotations(); if ( dim_list.length > 0 ) { var crv = crv_list.item(0); var dim = dim_list.item( dim_list.length-1 ); dim.text = moi.ui.formatCoordinate( crv.getLength() ); } }
Then create an angular dimension on the arc, then select the arc and trigger the script, it will update the angular dimension's text to the arc's length.
11229.3
amazing.
11229.4 In reply to 11229.2
Have you a little video about this script ?
11229.5
Thanks Michael, very handy!
www.jameselliott.co.uk
Show messages: All  1  2-5
