FR : surface ID data (integer) with the .FBX exporter.
All  1-2  3-9
11219.3
Hi Michael, I thought .lwo tag were more 'complex' than that.
No I don't "need" anything persistent between modelling session, but a way to get the individual surface id's from the Nurbs model without having to use the unweld export option.
Here's a filleted cube example. If we talk about smoothing group, there isn't any right ? (I don't see any need of splitting vertex normals in this example).
The way I create this data is by using a 'tag by connectivity' in Houdini, using the unweld feature in the MoI export options.
This allows me to iterate on every surface form the Nurbs model individually. The data is visualized here with random colors.
Houdini 'tag by connectivity' simply add an unique integer attribute for every polygon that are connected (and thus belongs to the same Nurbs surface).
The issue here by using unwelded models is that I can't really refuse the vertex in case surfaces are overlapping (like an perfect array of cubes, all the shared surfaces will be merge together).
I have also attached the result .fbx from Houdini with the data stored under the name "id" (could be any name). However at this point I'm not really sure if .FBX can actually store custom attribute or if it's an Houdini shenanigans.
This data is exported and reloaded properly only by using binary .FBX format (ASCII export discard it).
EDITED: 29 Sep 2023 by PAQ
11219.4 In reply to 11219.3
Hi PaQ,
Nope, it's just the same as smoothing groups. The only other thing is that if you have welding turned off it will have a separate part ID for each connected pieces.
If welding is turned on then there would be just one smoothing group (and one PartID in LWO) and all faces would be in that same group.
If welding is turned off then there would be a separate smoothing group/ PartID for each surface.
Why do they need to be merged?
Hmmm, well I was looking through the FBX SDK briefly and I couldn't find anything that looked like "surface id" in there, so this may be some custom information that only Houdini is looking for.
I have a tool "FBX Explorer" that diagrams the info in an FBX file, but it can't load your example file. Is it possible to generate an older FBX version, like 2013?
11219.5
Hello Michael,
So here's a 2013 version. I don't think there is indeed a specific attribute name like "surface_id" supposed to be used for that purpose.
However I just came across this example (maya to unity) where custom attribute is created and stored in .FBX file (even animated in this example) ... so it's not completely odd to store additional information with that format.
https://www.techarthub.com/how-to-import-custom-properties-from-maya-into-unity/
Having vertex merged is kinda useful to actually exploit "true" connectivity, like assigning materials or groups. In many polygon modeler it's common to simply double click on a polygon to select the whole connected mesh ... like a bunch of bolts that doesn't have any group/name set yet, you can just double click on them and tag them.
With the "unweld" options I have tons of individual surfaces (on purpose), very handy for uv'ing, but not so much for 'normal' selection work.
11219.6 In reply to 11219.5
Hi PaQ, thanks for the 2013 version .fbx, the "FBX Explorer" app is able to load that one ok.
Looking through there I see some chunks of data for Material, Normal, UV, and "UserData 0" and "UserData 1". So presumably one of the user data chunks is for the surface ID values.
Do you know if there is any documentation on how Houdini is expecting the surface ID user data to be structured?
11219.7
Hello Michael,
Thanks a lot to looking at this already !
I didn't find any doc about that subject, however maybe I did something wrong on my side previously, but the ASCII version works too now (maybe by switching to .FBX 2013).
Here's a simple cube example where I did assign a custom 'id' and saved as .FBX 2013 ASCII. I can see in a text editor the 'LayerElementUserData', describe as such :
LayerElementUserData: 1 {
Version: 101
MappingInformationType: "ByPolygon"
ReferenceInformationType: "Direct"
UserDataId: 1
UserDataArray: {
UserDataType: "Integer"
UserDataName: "id"
UserData: *6 {
a: 0,1,2,3,4,5
11219.8 In reply to 11219.7
Hi PaQ, can you please test this file to see if Houdini recognizes the surface id data that I've put in it?
- MIchael
11219.9 In reply to 11219.8
Hello Michael, that's perfect !!!! Thank you so much !
Show messages: All  1-2  3-9
