Suggestions on how to model this feature?
All  1-10  11-17
11215.11 In reply to 11215.10
Here is my initial look.
I can get the top view going.
11215.13 In reply to 11215.10
Hi Burr, how about setting an isometric view and then use Make2D or export to DXF using the 3D view projection?
Script for setting isometric view here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1917.35
11215.14 In reply to 11215.13
I wanted to make it with actual 3d cubes and lay them out and cut the bottom flat.
Was trying to set the cube to be rotated like that per my top or front view
I have been able to get it done also by rotating, though i loose my train of thought. I was looking for an explanation or method from you
11215.15 In reply to 11215.14
Hi Burr, so starting with a cube centered at the origin, first rotate it in the Top view by 45 degrees then rotate in the Right view by 54.736 like Brian writes above, or also you can snap the rotation onto the cube's corner with the first pick and then straight up with the 2nd pick.
Looks like this:
11215.16 In reply to 11215.15
Ok, much clearer than i was doing.
Thank you.
The solution, I gave before, seems easy and fast.
It's as Michael explained, to begin with an cutted hexagon and displacement of key points.
No theory, only practice.
I posted the file too if you want to see it.
Have an happy modeling !
Show messages: All  1-10  11-17
