dimensioned drawing multiple views workflow
All  1-8  9-13
11211.9
Hi everyone,
You could imagine making automated printouts like this with a few dedicated tools. In this case, I did it for fun, in a very home-made way.
I'd have liked to use coordinate dimensioning, but with my custom UI it doesn't work.
See link below
http://moi3d.com/forum/index.php?webtag=MOI&msg=11109.1
Note: I made this drawing from a drawing and a piece to create offered by TITANS from CNC: Academy Site.
In the end, MoI3D (for both the part and the drawing) worked quite well. As for me, I do it for fun, for the pleasure of 3D and to make my neurons work!
EDITED: 11 Nov 2024 by ZOOEN
11211.10 In reply to 11211.9
Hi Zooen,
Nice drawing :)
Re:
Do you mean this plugin?
http://moi3d.com/forum/messages.php?webtag=MOI&msg=11115.1
I can imagine that adding the icon might not work, but if you set up a shortcut key for "Ordinate" does that work?
- Peer
Message 11211.11 deleted 19 Sep 2023 by ZOOEN
11211.12 In reply to 11211.10
Hi Peer,
Yes
I did this and it works. Thanks
I noticed that it is therefore necessary, to carry out the dimensioning, to move the supposed (chosen) origin of the coordinates of the element that we want to dimension (the local 0.0) to the origin of the world (the 0.0 overall).
In the example case of my plan above, I have 3 local origins. So, 2 movements of all the elements (entities) created.
EDITED: 19 Sep 2023 by ZOOEN
11211.13 In reply to 11211.12
Hi Zooen,
Glad to hear you got the plugin working.
It sounds like you're moving the view of the part to the world origin adding the dimensions, and then moving the dimensions and the part away from the origin. I hadn't thought of doing it that way.
I set up local coordinates using the CPlane tool which lets me snap the coordinate system onto the part.
http://moi3d.com/4.0/docs/moi_command_reference5.htm#CPlane
For each view I have to set the local origin again. One problem with this approach is that there's a bug in my code and with some orientations of the local coordinates I get an error message, so maybe your method is better until I get a chance to fix that.
- Peer
Show messages: All  1-8  9-13
