dimensioned drawing multiple views workflow
All  1-3  4-13
11211.4 In reply to 11211.3
Hi Peer, the problem you're running into here is that the curves that look like a circle and arc are not precise circle or arc analytic curves, they are general spline curves that closely resemble a circle and arc but not quite to the (rather tight) precision level that MoI currently uses to detect if a curve is the shape of a circle or arc.
To solve this currently I think you would need to replace D with a 3 point circle and R with a 3 point arc.
You can do this by selecting the circle, then run Draw curve > Circles > 3 pts, place 3 roughly equidistant points and then hit delete to remove the original curve. Same thing with the arc except using the 3 pts Arc tool.
I guess there are a couple of possible ways to improve this so you wouldn't need to do that. One possibility would be to loosen the tolerance used to detect if any curve is a line, circle or arc.
Another possibility could be to allow a radius dimension to be put on any curve with the value using the curvature at the picked point. Rhino does this but it seems kind of dangerous.
Or another could be to do some shape analysis on the result of the projected curves in the 2D drawing generation and replace with exact circles and arcs at this spot. This seems like it may be the best way because the other methods could lead to a false sense of accuracy.
11211.5 In reply to 11211.4
I appreciate your thorough reply. I guess for now I'll manually re-draw with the arc and circle tools like you're suggesting, or maybe I'll continue to manually key in the dimension values using a leader like I have been.
Regarding the "shape analysis" option, are you saying this is something I could do by writing a script? Sounds pretty tricky.
- Peer
11211.6 In reply to 11211.5
Hi Peer,
I'm saying it's something I could do to the projected curves in the drawing generation.
It's possible to do it in a script, it's fundamentally just evaluating a bunch of points along the curve and see if they are close enough to a circle. But it can be tricky to do it well.
I'll give it a try as a part of drawing generation.
11211.7
Here is dimension drawing in MOI and yes the outer radius I achieve by tracing 3pt curve in position over the render.
11211.8 In reply to 11211.7
Thanks for the example AlexPolo.
- Peer
11211.9
Hi everyone,
You could imagine making automated printouts like this with a few dedicated tools. In this case, I did it for fun, in a very home-made way.
I'd have liked to use coordinate dimensioning, but with my custom UI it doesn't work.
See link below
http://moi3d.com/forum/index.php?webtag=MOI&msg=11109.1
Note: I made this drawing from a drawing and a piece to create offered by TITANS from CNC: Academy Site.
In the end, MoI3D (for both the part and the drawing) worked quite well. As for me, I do it for fun, for the pleasure of 3D and to make my neurons work!
EDITED: 11 Nov 2024 by ZOOEN
11211.10 In reply to 11211.9
Hi Zooen,
Nice drawing :)
Re:
Do you mean this plugin?
http://moi3d.com/forum/messages.php?webtag=MOI&msg=11115.1
I can imagine that adding the icon might not work, but if you set up a shortcut key for "Ordinate" does that work?
- Peer
Message 11211.11 deleted 19 Sep 2023 by ZOOEN
11211.12 In reply to 11211.10
Hi Peer,
Yes
I did this and it works. Thanks
I noticed that it is therefore necessary, to carry out the dimensioning, to move the supposed (chosen) origin of the coordinates of the element that we want to dimension (the local 0.0) to the origin of the world (the 0.0 overall).
In the example case of my plan above, I have 3 local origins. So, 2 movements of all the elements (entities) created.
EDITED: 19 Sep 2023 by ZOOEN
11211.13 In reply to 11211.12
Hi Zooen,
Glad to hear you got the plugin working.
It sounds like you're moving the view of the part to the world origin adding the dimensions, and then moving the dimensions and the part away from the origin. I hadn't thought of doing it that way.
I set up local coordinates using the CPlane tool which lets me snap the coordinate system onto the part.
http://moi3d.com/4.0/docs/moi_command_reference5.htm#CPlane
For each view I have to set the local origin again. One problem with this approach is that there's a bug in my code and with some orientations of the local coordinates I get an error message, so maybe your method is better until I get a chance to fix that.
- Peer
Show messages: All  1-3  4-13
