Multiple Offsets
11205.1
When i try to offset multiple items for inside it only allows one a time but outside offset allows me without problem. Is there a way to go about this? See photo for reference. Thanks
Size: 33.8 KB, Downloaded: 71 times, Dimensions: 1137x627px
11205.2 In reply to 11205.1
Hi Shamrock, the problem is that the same target point for inside/outside determination is used by each curve individually.
So you've picked a point there that is inside of one curve, but that same point is outside of the other curves. So it then follows that one curve is offset to the inside and the others to the outside.
For now to offset to the inside you'll need to do those one by one.
One thing I could probably do to help would be to allow a negative offset distance so you could then pick a point outside of everything and it would go inwards. Currently offset does not allow a negative distance but I'll look into changing that for the next v5 beta.
Thanks, - Michael
11205.3 In reply to 11205.2
Got it, thank you sir.
11205.4
Whit Fat Lines Script you can do offset in positive and negative direction in something like the example you provide.
