STEP import - color not being used?
 1-6  7-24
11202.7 In reply to 11202.5
Hi Andy,
> Thanks. Set to it 1,1,1 and it now works, but why is that needed?
It's because MoI displays a color of 0,0,0 as black for wires, but white for shaded surfaces.
The reason it does that is because if it didn't do that then the default style would display a sphere like this:
- MIchael
11202.8 In reply to 11202.6
Hi Andy,
> "Level 4" is the PCB. When I export as FBX and import into Davinci Resolve
> this has now become "level 2".
> Is that a bug in Moi3D changing the name on the export? If not then it must be a bug in Davinci
> Resolve changing the name on import.
I'm not able to reproduce any change in the names exporting the PCB object to .fbx and importing into Blender.
Can you please attach the .fbx file so I can take a look at your result?
11202.9 In reply to 11202.8
Attached.
11202.10 In reply to 11202.9
Hi Andy, thanks.
So with MoI v4 if I use File > Open on your COIA-CORE.step file, then I'm seeing the PCB assigned to Level 2, not Level 4.
Here's what it looks like over here:
If I select the green PCB part, it shows it has a style named "Level 2":
When I import your file V1.fbx , the PCB part also shows it has been assigned a material of "Level 2", matching the style assignments in MoI:
If you are getting different results than this then are you possibly importing your step file into a model that already has styles in it with those same names? Try using File > Open to bring the file into MoI instead of File > Import.
11202.11 In reply to 11202.5
So far I am getting 6+ permutations of Level # color (styles), just with File Open, of the COIA-CORE.step file.
Always 13 of them.
In Explorer, with MoI closed, or open, doing file open of COIA-CORE.step gives at least a couple of permutations.
With MoI open, doing file open of COIA-CORE gives a few more permutations.
I have seen the green style as Level 2, 3, 4, and 5.
ps, I do have a very pale blue/white style called Level 1, which was adopted several months ago. (From a Fusion import I recollect.)
11202.12 In reply to 11202.11
Hi Brian, I guess the ordering of the styles may vary with the multithreaded loading.
Does it become steady if you set [Settings] FileLoaderThreadLimit=1 in moi.ini ?
I should be able to improve that by sorting objects into their original order within the file after the multithreaded processing is finished. That's being done currently for 3DM files but not for STEP/IGES/SAT files.
11202.13 In reply to 11202.12
Success!!!
Setting the FileLoadThreadLimit=1 in moi.ini was successful in stabilizing the Styles (colors) from Andy's file COIA-CORE.step, when Opening the step file.
Opened Load Styles were consistently the same, for multiple trials...
It also seems to stabilize the Styles (colors) when doing step file Import. (On the first try, it seemed off, and doing a second file Import added the stabilized version below the first import...)
But additional trials of Import of step, after closing and re-opening MoI were the stable colors. (Unless there is some caching going on???) Additionally, doing a second Open of the Step did NOT add any additional Level Styles.
(My previous setting was ...Limit= (followed by nothing, no number).
image host
I assume that the above Styles (Level #'s styles) are the "correct" Step colors???
Thank you Andy.
ps The nearBlack rgb of 1,1,1 is still needed for Level 1
EDITED: 24 Aug 2023 by BEMFARMER
11202.14 In reply to 11202.3
>> You can Ctrl+click on the color swatch in the scene browser as a shortcut to get to the color picker.
I wasn't aware of that. It's really useful for me. Thanks Michael.
I'm just asking out of curiosity, Can we see the color changes instantly without needing to push the "ok" button?
Something like a preview for object color.
That'll save me a lot of trial and error.
Thanks again
11202.15
Thanks for the replies. Looks like Moi3D export is OK with the style names. Andy
11202.16 In reply to 11202.14
Hi MO,
Sorry no I don't think there is any method for this in the cross platform interface to the color pickers.
11202.17
When I load the FBX file into Davinci Resolve it separates out the objects/meshes (there is 20 or 30 of them) and they have names like "COMPOUND" and "SOLID". Davinci Resolve does not like multiple meshes having the same name and it is causing a bunch of issues in that application.
Looking at the Mod3D UI I see "COMPOUND" and "SOLID" but they are only listed once, not multiple times.
How can I separate all of these out and give them unique names?
Thanks, Andy
11202.18 In reply to 11202.17
If I import the same STEP file into Alibre Design all the parts have names, such as HVSON8, which is correct. Andy
11202.19 In reply to 11202.17
Hi Andy,
Do Ctrl+A to select everything, then click on the name line in the properties panel in the upper right which will say "(varies)", press OK on the "Edit object name" dialog without putting in any name there and the name property will be removed from everything. Then when you export that to fbx unique names will be automatically generated.
You also might try a setting in moi.ini :
[NURBS Import]
UseHierarchicalNames=y
That will change the way names are processed in the import into MOI.
11202.20 In reply to 11202.16
Thanks for your reply Michael.
11202.21 In reply to 11202.19
Thanks - that worked and Davinci Resolve seems happier, but it's not very intuitive - perhaps when exporting FBX Moi3D can detect this situation and ask if the user wants unique names?
Andy
11202.22 In reply to 11202.21
Hi Andy,
That would probably be kind of weird, I doubt I would be able to detect this situation automatically since it depends on the behavior of the particular app that you are exporting into.
The main way to improve this is probably to preserve the parent/child hierarchy in the STEP file with groups in MoI. But groups are new in MOI v5 and it will be a while before they percolate into import/export .
11202.23 In reply to 11202.22
I meant detect multiple meshes having the same name on export. Andy
11202.24 In reply to 11202.23
Hi Andy,
It's not a problem for many apps to have that.
Show messages:  1-6  7-24
