Delicate attention :)
All  1  2-6
112.2 In reply to 112.1
> Is not possible for the other Solids Cylinder and Cone?
> If width = height it will writed for example "Squared"
So you mean have a snap to make the height of the cylinder or cone equal to the radius?
I'm not sure that calling that "square" would be quite the right word. Is this something that you find you need to draw often? Cube is a very common shape, so I wanted to make it very easy to draw that freehand. It doesn't seem like a cylinder of height=radius is as common...
It's also a little different because with a box, the direction of the box height is fixed in just two up/down directions, so this makes it easy to have just two cube snaps. But when you draw a cylinder or cone, you are free to place the cylinder at any direction. I guess I could make snap points along the x,y, and z axes - but that would then be 6 snap points. I hesitate to add in too many snap points because if you get snap points everywhere they can get in the way and prevent you from placing points at certain smaller angles in a freeform way, if that makes any sense...
There is also another way to create this type of cylinder pretty easily already - before you draw the cylinder, drag out a construction line that follows the height that you want. Now place the base point of the cylinder at the start of that construction line, place the radius point at the other end, and then place the final cylinder point at the other end as well - you will have a cylinder that has radius = height. Also since the midpoint and reflected endpoints are available on construction lines, you can easily get a height = 0.5 * radius or 2 * radius as well. Let me know if you want some step-by-step instructions for this.
Also another way to get radius = height is to type in the same number for each of them...
> Is it possible to integrate a "Golden Section" when a rectangle is drawing?
Probably... I'll see what I can do.
112.3 In reply to 112.2
For radius = height maybe more easy in a dialog box ? But all that is for more confort not essential :)
Thx for the rest of explanations (very clear)
112.4 In reply to 112.3
That would definitely be easier. But is it really something that you need to do very frequently, where just one less click or so would make a difference?
If something doesn't need to be done very frequently, then it's sort of better not to have special options for it if there is a different way to do it pretty easily (like with just one extra step or something, like with a construction line in this case), because that really helps to keep the UI more streamlined.
I've got to be kind of careful not to just add in all conceivable options... But at the same time it is important to add in the options that are valuable. It's a delicate balance.
112.5 In reply to 112.4
You can forget this last complaint !
It's not a so frequent using and can be easily made as you say by one or 2 more clics:)
EDITED: 15 Sep 2006 by PILOU
112.6 In reply to 112.5
Please don't get discouraged from making complaints, though! It is helpful for me to hear all kinds of ideas.
Sometimes I won't use every single idea for one reason or another (which I will try to explain), but that doesn't mean that I don't want to hear them anyway!
Show messages: All  1  2-6
