FBX export settings
All  1  2-4
11199.2 In reply to 11199.1
hi Toha,
> I wonder to know if you are planning to improve the output quality of mesh while converting to fbx or obj formats.
There aren't any plans, I've already put in a lot of work in the past to improve the quality to the current level.
Do you have some examples where the current quality is not good?
11199.3 In reply to 11199.2
Hi Michael!
I have attached some screenshots. there are wireframe screenshots as well to show the overlapping vertexes.
There is a way i can merge these vertexes in blender, but it breaks normals.
Probably having merge function in moi3d would help a lot.
11199.4 In reply to 11199.3
Hi Toha, those vertices are generated so that the mesh is "watertight" and has a unified vertex structure along edges where the original NURBS surfaces are glued together.
It's a normal part of the current meshing method.
Some previous discussion here on how mesh vertex alignment works:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1536.30
http://moi3d.com/forum/index.php?webtag=MOI&msg=2102.45
http://moi3d.com/forum/index.php?webtag=MOI&msg=3869.2
Thanks, - Michael
Show messages: All  1  2-4
