MOI TO BLENDER SCALE IMPORT NOOB QUESTION
All  1-2  3-8
11192.3
Just FBX and got and error message version 6100 not supported must be 7100.
Alex.
11192.4
Just tried export via RHINO FBX 7100 and works perfect. Thanks for the advice is this something that MOI will be upgraded also?
11192.5 In reply to 11192.3
HI Alex, there is an option in MoI that you can use for that currently. In MoI go to Options > Import/Export > FBX options and set the option for "FBX version" to something later than 2010/6.1 .
11192.6
again thanks Michael works perfectly.
MOI seriously sharp pencil in the ol`TOOLKIT
Keep doing what your doing so well - Alex.
11192.7
If you want you can set Apply Transformations in the import dialog. This will set the scale to zero and make the model, well correctly transformed.
I had been using OBJ but after Micheal's comment I thought I would give FBX another go, it works perfectly.
3D Hard Surface
mbt3d.com Artstation
11192.8
Its easy to get stuck in old work flow formats and miss new formats after using STL and OBJ for decades its time to move - a new FBX fanboy!
Show messages: All  1-2  3-8
