Rebuild Surface Script
 1-9  10-29  30
11191.10 In reply to 11191.9
thx for the info! :)
11191.11
...OK here is a short Moi3d rebuild script test, with the Benz Base I modeled in Plasticity:
this script is simply awesome
EDITED: 14 Aug 2023 by ZARKOW
11191.12 In reply to 11191.11
Seems cool for your cars! ;)
ps format of your 2 images are some curious! Impossible to Zoom in!
Else some efficient indeed!
in 2 clicks!
And after if all faces planar wanted...or not...
SubDiv by Max Smirnov ...https://moiscript.weebly.com/subdivision.html
etc...
EDITED: 14 Aug 2023 by PILOU
11191.13 In reply to 11191.11
Nice!
Looks like your cad/subD method matches very well with this script.
Soon, I'll post a tutorial to show my surface merging process.
11191.14
Hi
In attached images, I've shown you 2 methods for merging surfaces with the help of "Rebuild Surface" script.
Size: 107.2 KB, Downloaded: 310 times, Dimensions: 1700x500px
Size: 106.7 KB, Downloaded: 355 times, Dimensions: 1330x500px
Size: 129.3 KB, Downloaded: 353 times, Dimensions: 2160x500px
11191.15
Nice i've been struggling to understand this.
Tnx!
11191.16 In reply to 11191.14
How do you snap the points ?
Manually or by Scripts ?
11191.17 In reply to 11191.16
Hi
I'm doing it manually. :)
11191.18 In reply to 11191.17
Seems i remember something about that with a "tolerance" ?...
maybe in exporting...
Else what are exactly the 4 methods ?
11191.19
Hello MO_TE, a big thank you for your script which will become one of my best friends, and thank you again for your last explanations, I didn't understand everything either.
11191.20 In reply to 11191.1
Hi! Thank you for creating this plugins.
Could you explain the differences between methods 2 - 3 - 4 and their respective interest?
- Zooen
11191.21
I was looking at this tutorial https://www.youtube.com/watch?v=RL_mgs_jwHM
What is the purpose to running the subD classic before the subD beta?
EDITED: 18 Aug 2023 by MATADEM
11191.22
Hi everyone
I'm not sure I can explain them without making you more confused, But, Let me try! :)
All the methods you've seen can be reproduced manually with moi commands.
Here is an explanation for each method:
Method 1:
It'll extract borders and isocurves of the input surface, then network them to make a new surface.
It works only on untrimmed surfaces. And it's useful when smoothing or trimming surface.
Method 2:
Extracts only the surface borders and network them to make a new surface.
It's a fast method. But the results can be inaccurate on complex surfaces.
Method 3:
It is very similar to "method 2"
Except that It'll run "method 1" on the surface created by "method 2". (Sounds like overdoing, but in some situations it'll be useful)
Control points are more uniform with this method.
Method 4:
It'll run the "flow" command on the isocurves created by "method 3", with the surface created by "method 2" as base and the input surface as target.
Then it'll network the "flowed" isocurves and borders of input surface to make a new surface.
When rebuilding a complex trimmed surface, this method is your best chance.
Methods 2 and 3 also can rebuild trimmed/untrimmed revolved surfaces.
In the attached file, you can see the difference between the 4 methods with similar settings on a relatively complex surface.
Some methods may look similar, But the control points and isocurves are different.
11191.23 In reply to 11191.22
THX! A little more clear! :)
Explanation added to the French version!
https://moiscript.weebly.com/rebuild-surface.html
EDITED: 19 Aug 2023 by PILOU
11191.24 In reply to 11191.22
No, This confirms and completes my deductions following the tests I did myself. Thank you for your reply.
- Zooen
11191.25 In reply to 11191.1
Supercalifragilisticexpialidocious!
Thanks! Great job!
11191.26
Thank you so much for the script
that just saved my project in the right time
EDITED: 15 Jan 2024 by PRINCOROYAL
11191.27
Thanks for this script, very nice addition to MoI's tools.
11191.28
One of the best Scripts for Moi3D, after months underrated
https://www.instagram.com/p/CzbYVoYKHyK/
11191.29 In reply to 11191.28
Advertising Plasticity or rebuild surface?
Just asking for a friend... ;-)
Show messages:  1-9  10-29  30
