Rebuild Surface Script
 1-20  21-30
11191.1
I made this script to speed up the process of reconstruction surfaces inside moi.
It can:
Reconstruct 3 and 4 sided surfaces
Extract isocurves and borders of the surface (To merge surfaces)
Trim surface (For retopology or subD workflow)
Improve "Flow" and "Blend" commands on trimmed surfaces. (See screenshots)
Here is a quick introduction for each part of the ui:
Method: 1 construction method for untrimmed surfaces and 3 methods to reconstruct trimmed surfaces.
Resolution: Changes points density of the surfaces. (Surface quality)
" U " and " V " sliders: will affect on curves section, trim section and overall surface quality.
Curves: extracts isocurves and borders of the surfaces by U and V numbers.
Trim: trims the rebuilt surfaces by U and V numbers.
Merging small patches into one big surface:
Blend command before and after using "rebuild Surface" script:
Flow command before and after using "rebuild Surface" script:
Ready to subD!
Some points to keep in mind:
It works only on surfaces with 3 and 4 edges and revolved surfaces (e.g. spheres, pipes).
It can work on multiple surfaces at once.
Selected surfaces must be separated. (Joined surfaces are not allowed)
Method 4 can be much slower than others, especially on complex surfaces. (Save your work!)
A Very high points density or u-v number may break the surface. (Save your work!)
It cannot merge the surfaces automatically. Just makes it easier sometimes!
Super cool!
11191.3 In reply to 11191.1
French Version
If you have a site I can add anything you want as personal link! :)
https://moiscript.weebly.com/rebuild-surface.html
EDITED: 13 Aug 2023 by PILOU
11191.4 In reply to 11191.1
Wow, this has the potential to take moi3d to a new level.
This looks like one of the important scripts for Moi3D fantanstic.
I have test it short, it runs great, in 2 or 3 weeks I have time to test it in real modeling situations.
But tomorrow go to my holydays.
11191.5
amazing so easy.
11191.6 In reply to 11191.5
Dear MO_TE
Thank you so much for this amazing script that you wrote, that gives you the potential to do and edit Surfaces.
Hope the new Moi v5 have more script commands like this.
Thank you so much.
11191.7
Thanks Pilou
That's cool. I'll let you know. :)
>> Zarkow, AlexPolo and RayCAD
You are welcome and thanks for your Encouragement
I'm looking forward to see you and other users using it.
Also thanks to Michael for answering my questions tirelessly.
I used his helps a lot.
Have fun
Sorry but what is W/O ?
11191.9 In reply to 11191.8
It is shortened form of the word "Without".
You can use one of these options if you don't need the rebuilt surface itself.
"IsoCurves W/O Surface"
"IsoCurves + Border W/O Surface"
11191.10 In reply to 11191.9
thx for the info! :)
11191.11
...OK here is a short Moi3d rebuild script test, with the Benz Base I modeled in Plasticity:
this script is simply awesome
EDITED: 14 Aug 2023 by ZARKOW
11191.12 In reply to 11191.11
Seems cool for your cars! ;)
ps format of your 2 images are some curious! Impossible to Zoom in!
Else some efficient indeed!
in 2 clicks!
And after if all faces planar wanted...or not...
SubDiv by Max Smirnov ...https://moiscript.weebly.com/subdivision.html
etc...
EDITED: 14 Aug 2023 by PILOU
11191.13 In reply to 11191.11
Nice!
Looks like your cad/subD method matches very well with this script.
Soon, I'll post a tutorial to show my surface merging process.
11191.14
Hi
In attached images, I've shown you 2 methods for merging surfaces with the help of "Rebuild Surface" script.
Size: 107.2 KB, Downloaded: 310 times, Dimensions: 1700x500px
Size: 106.7 KB, Downloaded: 355 times, Dimensions: 1330x500px
Size: 129.3 KB, Downloaded: 353 times, Dimensions: 2160x500px
11191.15
Nice i've been struggling to understand this.
Tnx!
11191.16 In reply to 11191.14
How do you snap the points ?
Manually or by Scripts ?
11191.17 In reply to 11191.16
Hi
I'm doing it manually. :)
11191.18 In reply to 11191.17
Seems i remember something about that with a "tolerance" ?...
maybe in exporting...
Else what are exactly the 4 methods ?
11191.19
Hello MO_TE, a big thank you for your script which will become one of my best friends, and thank you again for your last explanations, I didn't understand everything either.
11191.20 In reply to 11191.1
Hi! Thank you for creating this plugins.
Could you explain the differences between methods 2 - 3 - 4 and their respective interest?
- Zooen
Show messages:  1-20  21-30
