Why does an additional tapered extrude on this spindle result in isolated face ?
All  1-3  4-6
11189.4 In reply to 11189.3
Thanks for replies. FWIW, I can reproduce at will by starting with the just the attached joined surface and then drawing a cylinder within the surface followed by alternating tapered and regular extrudes.
Sven
11189.5 In reply to 11189.4
Hi Sven, yes it looks like the tapered extrusion surfaces can get pretty dense. If you need to do a sequence of several in a row you may be better off instead putting in circles and then using Construct > Loft > "Loft style = Straight".
11189.6 In reply to 11189.4
Actually for this type of thing that is circular around a single axis line it would probably be best to use Revolve.
Show messages: All  1-3  4-6
