Why does an additional tapered extrude on this spindle result in isolated face ?
All  1  2-6
11189.2 In reply to 11189.1
Hi Sven,
Perhaps I'm wrong, but, when I open your file, the cylinder is a solid but seems having missing part or invisible part between its cap and the rest of cylinder.
Normal ?
nothing hidden but an hole.
And this "hole" is a surface too. Strange surface because it has 2 edges and those edges are 1 curve and 1 closed curve.
Having this type of surface is potentialy a source of strange thing.
EDITED: 11 Aug 2023 by PHIRO
11189.3 In reply to 11189.1
Hi Sven, somehow the trimming boundaries on the tapered part have become corrupted, that's why it's not getting displayed properly.
I've attached a repaired version.
11189.4 In reply to 11189.3
Thanks for replies. FWIW, I can reproduce at will by starting with the just the attached joined surface and then drawing a cylinder within the surface followed by alternating tapered and regular extrudes.
Sven
11189.5 In reply to 11189.4
Hi Sven, yes it looks like the tapered extrusion surfaces can get pretty dense. If you need to do a sequence of several in a row you may be better off instead putting in circles and then using Construct > Loft > "Loft style = Straight".
11189.6 In reply to 11189.4
Actually for this type of thing that is circular around a single axis line it would probably be best to use Revolve.
Show messages: All  1  2-6
