multiple instance file handling scripting
All  1-2  3-7
11188.3 In reply to 11188.2
Thank you for thinking about this problem, for the shortcut keys, and for the code snippet.
Seems like it might get fairly involved especially to do it on both Mac and Windows.
How about a way to prevent MoI from starting if the startup script detects a condition? It's not the prettiest solution, but would probably be good enough for my use.
I tried doing this by doing moi.exit() in a startup script, but that causes the new instance of MoI to freeze permanently. Seems like doing moi.exit() in a startup script before the graphics get displayed causes a problem, since it works fine if I do moi.exit() manually right after the graphics load.
Are there any alternatives for causing MoI to exit or a trick to get moi.exit() to work in a startup script?
- Peer
11188.4 In reply to 11188.3
Hi Peer, there is a different type of startup script used for batch processing, where you pass in the script path as a command line parameter to the MoI executable.
http://kyticka.webzdarma.cz/3d/moi/#Batch
Try using that type instead, does moi.exit( true /* suppress save changes */ ); work ok?
11188.5 In reply to 11188.3
Hi Peer, also over here I'm not able to reproduce the freeze when calling moi.exit( true ); from a startup script from the "startup" directory.
Does it happen for you if the script just consists only of:
moi.exit( true );
11188.6 In reply to 11188.5
Re:
Good to know, but I don't see how I could use that in this case. I need the startup script to run when I just click on a file in macOS Finder that I've set to open with MoI. I guess that the instance of MoI launched by the OS could run a script from the startup folder that uses shellExecute to run that kind of script, but that seems like it would cause many instances of MoI to start since each would see the script in the startup folder and I'd still have the problem of getting the first one to exit.
Re:
> Does it happen for you if the script just consists only of: moi.exit( true );
Yes if there's another script present in the startup folder that replaces some innerHTML with something involving a command button that includes onclick like this:
var CommandBarFlex = moi.ui.findElement('CommandBarFlex');
CommandBarFlex.innerHTML = '<moi:CommandButton onclick=""></moi:CommandButton>';
but moi.exit() in the first script works fine if the second script only inserts stuff involving command and not onclick like this:
CommandBarFlex.innerHTML = '<moi:CommandButton command=""></moi:CommandButton>';
One puzzling thing is that the freeze occurs regardless of the filenames involved. I thought that startup scripts get executed in alphabetical order, but if the exit script has a name starting with a letter in the middle of the alphabet (like startupScript.js) then it doesn't matter whether the name of the onclick script is a.js or z.js a freeze still occurs. I expected that MoI would exit as soon as startupScript.js runs and z.js would never be reached.
- Peer
11188.7 In reply to 11188.6
Hi Peer,
Thanks, I can reproduce that now, it is a shutdown bug if a control is inserted dynamically but then MoI exits before the control has finished initializing.
I've got a fix prepared which I'll send to you.
When you call moi.exit() , the moi process is not immediately terminated, a close message is posted to the main window so it will follow the same procedure as the regular window close button being pushed.
So moi.exit() initiates the closing procedure but the app won't actually terminate until after the startup scripts have run and the main event loop processes the posted close event.
I'll set it up so that it will stop executing any more scripts once one has called moi.exit(), and maybe the alphabetic ordering is not working properly I'll check. EDIT: sorting seems to be working ok.
EDITED: 11 Aug 2023 by MICHAEL GIBSON
Show messages: All  1-2  3-7
