Smoothing surface point in MoI3D
All  1-2  3-14
11183.3 In reply to 11183.2
The file's uploaded.
You might try extracting several isoparms except skipping the area that you want smoothed, and then use Construct > Network to build a new surface.
That's the solution too, thanks! I know many ways how to do it by hand. However, I would like to understand if it can be done with scripts or something else.
Manipulating the surface control points directly can have poor results if the surface is not uniformly parameterized.
Let it be left to human conscience, because any tool has limitations. The main thing is to have this possibility, to smooth the points/surface points.
11183.4 In reply to 11183.3
Hi Moi3dFan, sorry there is not really enough information available to scripts to be able to do that currently.
11183.5 In reply to 11183.4
In any case, thanks! I understand what you meant by this toolkit, and as a result, your solution is very elegant. The surface point tools are a tricky process in places. And if you do one function, you will have to do another, and so on. And everything can grow into a tool that is difficult to understand.
But if we talk about selection tools. Is there any way to highlight a row/column of points on a surface? Or Grow/Shrink selection of points?
11183.6 In reply to 11183.5
Hi Moi3dFan,
Sorry no there isn't a way to do either of these things currently.
Surface control point manipulation generally works better with sub-d surfaces instead of NURBS surfaces.
You may want to use a sub-d modeling program to do surface point manipulation type work and then convert the sub-d surface into MoI using SubD > Create > "From file".
11183.7
Yesterday the first time, I heard from this script, in the plasticity discord group, it's gold.
11183.8
Hi
Recently I was working on updating one of my nodes for nodeeditor (quad repatch)
It turned out that it works well for regenerating surfaces, so I decided to make a script from it.
Although it wasn't designed to smooth surfaces, but you can use it for doing this as well.
The script is almost finished. Just need to do some final tests.
11183.9 In reply to 11183.8
This is great! The script will work within the Node Editor, right?
I would have already tested, I'm very curious)
11183.10 In reply to 11183.9
Hi Moi3dFan
It is a script, so you can run it inside moi. ( Also I'm working on node version of it . )
11183.11 In reply to 11183.10
So the future script or nodes put control points on surface ?
11183.12 In reply to 11183.11
It rebuilds the surface with any number of control points you choose.
Like this simple plane that I rebuilt it with all these control points and then moved the points.
Or this one that I reconstructed, and decreased its control points.
11183.13 In reply to 11183.12
That's really cool! I look forward to hearing from you
11183.14 In reply to 11183.13
For people looking for it in the future.
https://moi3d.com/forum/index.php?webtag=MOI&msg=11191.1
Show messages: All  1-2  3-14
