STEP export/import a bit off-topic
All  1-3  4-8
11179.4 In reply to 11179.3
Hi PaQ,
> Is this torus suffers from this same "limitation" ? (I don't care that much tho, unlikely I will use that product)
No this seems to be a different problem.
If you edit the line in the file that has this:
#21 = EDGE_CURVE('',#22,#22,#24,.T.);
to this:
#21 = EDGE_CURVE('',#22,#22,#24,.F.);
then it appears to come in ok. It will take me a bit to figure out if it's something that is being interpreted wrong by MoI or whether it's an error in the file structure.
11179.5 In reply to 11179.4
Oki ! Nothing really important really ... all I can say is that it opens 'fine' in CAD Assisant (don't even remember why I have that thing installed).
Also it was supposed to be a boolean between a torus and a sphere, only get the donut exported obviously ... might as well be something wrong with that Beegraphy stuff.
11179.6 In reply to 11179.5
Maybe take a look at this free one online (Beegraphy on steroids! ;)
https://cables.gl/
11179.7
Interesting.
I made the same geometry from scratch in Moi and when I export that as STEP it opens correctly in Rhino and Fusion.
But obviously it's not constructed exactly the same as the model in beegraphy, so maybe I can't compare the result.
11179.8
I found a workaround and have notified the beegraphy-team.
By extruding a surface instead of a curve the export works great and can be imported in Moi, Rhino and Fusion.
Thanks for the explanation why imported CAD-data might differ in different software.
Show messages: All  1-3  4-8
