hexagonal grid
 1-15  16-24
11175.16
Here's the resulting pattern + source .hip
There is an extra ramp to control the 'speed' of the morphing between the hex and the circle ... time to clean the mess tho, I was aiming to the result first.
Two attempts to flow a hex grid to a hemi-sphere did not produce the desired patterns.
One attempt was with "square" iso-lines.
The other attempt was with "radial" isolines. (A disk and revolved quarter circle.)
11175.18
Tried this in modo with a flattened tessellated hemisphere and radial falloff.
Size: 960.5 KB, Downloaded: 145 times, Dimensions: 2742x1484px
11175.19 In reply to 11175.18
But that's pentagons :S (I like the approach tho !)
11175.20
Auck! you're right! Got into it, and completely missed the point.:(
So I am thinking of a Stereographic projection of 2D hex grid with centerpoint in each hexagon, and perhaps a gradient of circle sizes in each hex, to a half sphere.
Stereographic projection maps 2D circles onto sphere, as circles.
Then squash the half sphere by projecting it straight downward. This will turn the circles on the half sphere, into "ellipses" on the 2D plane.
11175.22 In reply to 11175.21
Tried another attempt at this using Steve Hills Harry Kit - Array Create Op. and concentric circles, not as tight packing as with Hexes.
11175.23
11175.24 In reply to 11175.23
Cool! Thanks!
Show messages:  1-15  16-24
