3D for 2D Faster Way
All  1-4  5-14
11173.5 In reply to 11173.3
Okay i think i was able to upload
11173.6 In reply to 11173.1
Hi
> I've modeled out a shelving component and i was wondering if there is a quicker way to
> extract solid into 2d vector for CNC. As for now im linking each individual polyline
> from 3D model into 2D and its a little time consuming.
> Is there a quicker way? Thanks alot.
There isn't anything built in to moi to expedite that but there are other CAD programs that could help with that type of CNC preparation.
Probably check out Fusion360.
11173.7 In reply to 11173.6
Okay, thanks Michael I thought maybe i was missing a little gadget and to give it a shot and ask.
Thanks again for your quick reply its much appreciated!
11173.8 In reply to 11173.1
Or also there are probably some Rhino plug-ins that would help with this:
https://www.food4rhino.com/en/app/easycut
11173.9 In reply to 11173.8
Thank you I will check out this.
11173.10 In reply to 11173.7
Hi Shamrock,
Sorry no MoI is focused more on the drawing and modeling areas and not on CNC processing functions.
You should be able to find other software that could help with that area though.
11173.11 In reply to 11173.10
Completely understand, thanks :)
11173.12 In reply to 11173.1
I am currently working in an office where the owners are designing and building new pin ball game machines using MOI3D and a massive CNC router.
While I don't know the specifics, I do know that the designer uses MOI3D STYLES to export to Adobe Illustrator files in layers as part of the workflow. Each layer defines not only the shape; but, the tools and depth of the cutter. I will be in the office on Friday and will see what I can learn about his workflow.
Tom
11173.13 In reply to 11173.1
Hi Shamrock.
I use this method.
https://disk.yandex.ru/i/zqrNORyzsaINJA
11173.14
Great tip!
I would say the make2d script will also work if there is an option to generate the topview only (depends how it is drawn).
after this to be imported in Vectric apps to generate the toolpaths.
EDITED: 27 Aug 2023 by MATADEM
Show messages: All  1-4  5-14
