Please help in this difficult math geometry quiz.
 1-7  8-27  28-47  48-67  68
That nephew must have access to a CAD program with constraint feature :)
x is equivalent to a scale factor. So x = 1 or 10, or even 100 is good.
The base chord, (x*sqrt(2)), can be generated as the hypotenuse of a 45 45 90 triangle with two sides of x*1 unit(s), by pythagoran.
The fact that 4 chords are of equal length x*1 units, implies that their central angles are equal, so the rotation angle from one to the other is equal,
with a value of approximately 114.81 degrees +/-. There are 3 of these equal angles, I am calling phi.
The angle at A2, of approximately 97.78, (I'm calling it theta), must be adjusted so that all vertices fit on the 3point circle.
Every time angle theta is adjusted, the angle phi also changes, by the simple formula previously given. So all of the x*unit chords keep changing as the candidate theta value changes. So they need to be redrawn over and over.
Constraining the 3 angles phi to a function of theta, would solve the puzzle, if the Cad program had constraints, and correct snap(s).
I guess a MoI script or a node could be written with an epsilon of the error of intersecting the centerline at C with chordBC?
Keep running the adjustment of theta, until epsilon reaches zero?
My 2018 Alibre program is in a zip file.
I was able to run Barry's node program. (After replacing Display node. Either my copy or Barry's must be old?)
It draw's close approximations to the solution, subject to visual adjustment to approach a solution. (As far as I can tell.)
I do not have enough knowledge of MoI to go much further.
Trigonometry can replace phi with a function of theta, but the resulting equation would still likely require numerical methods to solve. (?)
EDITED: 31 Jul 2023 by BEMFARMER
It seems like people are solving the geometry kernels job.
But integrityware already does all that.
If you specify X or x√2 or the circle radius, then the rest is a few seconds in MoI.
Same if you want to calc from any given value of those 3 objects.
No need for constraints of any kind.
Unless you are trying to program automation of the process. Then i’ll step out and watch.
11167.30 In reply to 11167.25
Hi, Barry.
This could be exactly what we need!... Thank you very much.
Now I just need to browse the forum to study how NOD works in Moi.
Cheers!
PS: This could be a prove that constraints is possible within Moi! How about integrates constrains to Moi, Michael? :)
11167.31 In reply to 11167.26
Hi BurrMan,
- The horizontal line of A1-A2, with x√2 length comes first in the quiz.
- Followed by the 2 magenta lines with x length connected each other
- Arranged (move and rotate) the magenta lines in particular way
- ... so that if we draw 3 points circle (RED colored) through point A1,A2, and B, then it would also 'touch' C
- C should be on both Red Circle and V axis.
Cheers.
11167.32 In reply to 11167.28
Hi, Brian
Indeed it needs a constrain feature like i mentioned in the original post. But nephew only have Moi and love it so much that I won't 'spoil' him with other app which made we want to solve the quiz ONLY in Moi. Also, seems like you're much more smarter than me in math, so I can't understand much of your 'math talks' in your posts. But I appreciate much for the effort and please continue to do so if you please. :)
Cheers!
11167.33 In reply to 11167.29
Hi BurrMan,
Yes it is... Only in the quiz, the red circle comes in the last order which make it tricky. ^_^
11167.34
Hi All
I just found the video which very close to the quiz above, and how to solve it... only, it's done via Inventor using constraints like my friend sugested:
https://youtu.be/1xsWKAoXYk4?t=21
(it is in 0:21 through 1:08)
cheers!
11167.35 In reply to 11167.31
Hi Elang,
- The horizontal line of A1-A2, with x√2 length comes first in the quiz.""""""""""""
Here is a video I made creating a random x√2 value.
It works with any of the other 3 values given at any value.
The V axis is also irrelevant. All the rotation in the video is just to express it. The 3 point arc is valid. If you had geometry in some random world coords that you didnt want to move and rotate around, you could create a CPlane in that area on the Axis of your choice.
EDITED: 31 Jul 2023 by BURRMAN
11167.36 In reply to 11167.34
They use constraints in inventor because thats how inventor works!
Also, notice the 60x60x60 triangles the guy in inventor makes @1.08
He’s really just making random connection lines then telling them to be 60x60x60 triangles (his constraints)
But we want your nephew to understand trig
Also, he wants to do it in MoI! Its a simple solution with MoI’s toolset.
11167.37
Here is another way to build a regular pentagon without using calculations or constraints.
While not the fastest way, it shows an easy method to get a 36 degree angle.
Hope you will find it interesting. Trig without inTrigue...
Radius of circumscribed circle of an irregular polygon
https://math.stackexchange.com/questions/2799954/finding-diameter-of-circumscribed-circle-of-an-irregular-polygon
Uses the Law of Cosines.
This can be used for the PentaChord puzzle.
m = number of sides with length A
n = number of sides with length B
The formula is:
m * arccos( 1 - ( A*A / 2*r*r ) + n * arccos( 1 - ( B*B / 2*r*r ) = 360 degrees.
For our puzzle, using length scale of x = 10:
m = 1
A = 10 * sqrt(2)
A*A = 100 * 2 = 200
n = 4
B = 10
B*B = 100
arccos( 1 - ( 200 / 2*r*r ) + 4 * arccos( 1 - ( 100 / 2*r*r ) = 360 degrees
So the function to solve for is:
arccos( 1 - ( 100 / r*r ) + 4 * arccos( 1 - ( 50 / r*r ) - 360 degrees = 0
Radius "r" must be solved for. (with 40 year old calculator ? :-)
or solved with an Excel spreadsheet. (Somehow)
I think that the 360 is subtracted on the left side, setting the equation to 0?
Also see if the arccos is dealing with degrees or radians???
Increment "r" until some tolerance is achieved.
For scale x = 10, the approximate value of "r" is 9.2814, which is probably less that the actual value of "r".
(Some other values of approximate "r" are 9.2822, 9.2826.)
Might try an online calculator to test approximate "r" of 9.2814, to see if it is close to 0?
With some learning I could probably do the Excel "macro".
https://en.wikipedia.org/wiki/Bisection_method
I suppose this could be done in Javascript?
Yes, this is breaking the "No Math" rule :-)
11167.39 In reply to 11167.38
I used the computers calculator, manually with the formula, with test "r" = 9.2814, which resulted in 360.02368331... minus 360, which is close to zero.
Which is encouraging.
I have not yet tried to do a function solve...
Actually, a quick Excel spreadsheet can replicate the Radius function equation, for a multitude of candidate radii. Maybe tomorrow.
11167.41 In reply to 11167.1
Hi
It's a very interesting and difficult quiz to solve inside moi. Looking at the math makes me dizzy. :)
I kinda solved it inside the nodeeditor by brute forcing the quiz conditions. (With 0.005% tolerance)
Take a look at attached file.
11167.42 In reply to 11167.41
Hi MO,
My nodeeditor has the wrong node, infos>Display
Where is the latest Display node? I have Jame's Sept 14, 2020 nodeeditor version. Is it still the latest?
Also, I do not have the "Blue/Green/Teal" nodes which have one input, and have Title, Style, and Edges, where the Title serves as a label.
Where is a copy of this node located?
After replacing Display node, and removing the several "label" nodes, your script ran.
Your Radius shows as 0.9293, for Scale X = 1
The length of your 4 unit chords are different, and do not equal 1 unit.
zooming way in shows top and left points slightly outside of the circle.
-Thankyou
EDITED: 1 Aug 2023 by BEMFARMER
11167.43
Hi All,
I think I've solved it, though there are few very tiny errors...
So I made plenty-plenty trial n error by rotating the green circle (on the right) with A2 as its pivot. Every time I rotate this circle, I make a 3pt Circle (red) through A1,A2, and B, to check if this circle intersect all this circle, green circle, and vertical axis in exactly one point... The goal is to make this red circle touch all of A1, A2, B, and C where C must be on the Vertical Axis. It's very impractical but does the job, I guess..
As you can see, there is very tiny difference at the red circle radius where the vertical radius has a 0.0000001 deviation from the other. Also, the angle of C and B differs about 0.0000011 deg. I think this is good enough (?)
I'm still looking forward for much simpler and better solution, though... so please write anything should you feel necessary.
Cheers!
11167.44
Here is another one. It respects the 2 statements "x" and "x * square root(2)".
The key is to circumscribe the pentagon instead of inscribe it.
With circumscribing, it is possible to use Tangent snapping.
Mirror History and rotation to tangency are essential to "fit" the sides.
EDITED: 1 Aug 2023 by VINC
I dd an Excel spreadsheet to calculate the Radius, semi-manually.
A scale of X = 10 was used.
MoI seems to allow a setting of 7 decimal places.
Note: A scale of 1000 with 7 decimals does not seem to work well in MoI, as far as snaps and intersection went. (?)
At X=10, the best Radius, limited to 7 decimals, was 9.2819138 units
In Excel, the error was -1.61E-8
A more precise Radius, with 13 decimals, was 9.2819137798526, with error of 2.50733E-12, BUT I think that this value is unusable in MoI (?)
At X=100, the best Radius, limited to 7 decimals, was 92.8191378, with error of -1.16072E-10.
So there is not a "Perfect" solution, with the number of decimal that can be used. The radius value might be transcendental.
The Excel formula in cell B29, which references the variable values, for Radius cell A29, is:
=$B$22*ACOS(1 - $C$23*$C$23/(2*A29*A29))+$B$24*ACOS(1-$C$25*$C$25/(2*A29*A29))-(2*PI())
The Excel spreadsheet is attached, and with a little practice, anyone can build one. Spelling error, radans should be radians. (ACOS() uses radians not degrees of angle.
I learned the rudiments of Excel many years ago.
So the puzzle can be built in MoI, using the "best" radius of 7 decimals, at X = 10, or X = 100.
image host
11167.46 In reply to 11167.42
Hi Brian
-- My nodeeditor has the wrong node, infos>Display
I'm not sure which version I'm using. Maybe mine is the one that is outdated.
The "Display" node initially was inside "r2d3" menu.
-- Also, I do not have the "Blue/Green/Teal" nodes
These nodes are "output" nodes that I changed their colors and used as label. (right click on the node >> "colors")
Also, you can double click on the canvas. This way the node's name and address will be displayed in the properties panel.
11167.47 In reply to 11167.44
Hi, Mip...
But part of the quiz is all of the vertices MUST be in a circle circumference...
So, from the screenshot, if you pick any 3 of the 5 vertices as references for a 3 point circle in Moi, then ALL of them should be exactly on this circle circumference.
Show messages:  1-7  8-27  28-47  48-67  68
