Chocolate Mold
 1-5  6-22
11164.6
Another view of chocolate.
As for the volute of a violin, for my part, I cannot find a satisfactory solution. Well for now.
- Zooen
EDITED: 18 Aug 2024 by ZOOEN
11164.7 In reply to 11164.6
Deleted see later post
EDITED: 3 Sep 2023 by BARRY-H
11164.8 In reply to 11164.1
Here is my tip:
But when I look at that piece of chocolate and think of a Mould, I see the center of the twisting looks like it is at an angle.
We might think this is done due to drafting requirements for chocolate release after cooling. My method just uses the default plane with no angles added to the Mould.
I cant do it by eye. I would need an advanced Moulding software to calc the drafting releases on such a spiral and cut... then I would rotate the result around and hack off the top and bottom to use as the cut for the Mould.
11164.9 In reply to 11164.8
And Solids ++ wins the fillet!
11164.10 In reply to 11164.5
Hi Barry,
@If of some interest will post file.
I'd be interested to see how you made this chocolate candy (very close to the real thing, thank you).
Hi Burman, your approach is interesting, thank you.
As for violins, I know of only two artists who have mastered the subject: Cristóbal Vila, with Modo, and Ivan Kukucov with Blender (there may be others....?).
I have a whole stock of documents and videos on violins. With MoI3D, it's the Volute that's giving me trouble. I keep coming back to this subject, I'm not giving up!
Image 1 Cristóbal Vila > https://etereaestudios.com/2020/04/07/tutorial-violin/
Image 2 Ivan Kukucov > https://www.youtube.com/watch?v=aDdG91iEoH4
11164.11 In reply to 11164.10
Deleted see later post.
11164.12 In reply to 11164.8
I realized after the fact that my piece was not correct. The ramp starts tangent to the circle at the bottom.
Just 2 curves + sweep or NetWork and then plane top and bottom don't make the trick?
i don't yet yet try...
11164.14
Inspired by Barry's first two steps and with a passage through Blender and a return to MoI3D to finalize.
11164.15 In reply to 11164.14
Hi Zooen,
I've found this method using solids rather than surfaces gives a better result.
The slope runs out before getting to base.
Anyway glad you have got a result with the surfaces method.
Barry
11164.16 In reply to 11164.15
Hi Barry,
>I have found that this method using solids rather than surfaces gives a better result.
The slope peters out before reaching the base.
Yes that's right, good job!
- Zooen
11164.17 In reply to 11164.16
Hi Zooen
Try this node file. It makes the spiral shape you are looking for.
To make this work I had to modify the "sweep" node, So it can accept the "flat" option.("Sweep.js" is attached.)
Replace the "sweep" node inside "Construct.js" with attached .js file
You need to do the lofting and trimming manually. :)
11164.18 In reply to 11164.17
Hi Mo,
can't get your node to work.
All nodes look ok.
Barry
Size: 47.9 KB, Downloaded: 35 times, Dimensions: 504x378px
11164.19 In reply to 11164.18
Hi Barry-H,
Your picture looks the same as the result from my computer
I did add the new Sweep.js to the node extensions folder.
Is there some other Sweep,js that needs to be deleted?
11164.20 In reply to 11164.18
Hi Barry
Sorry, I should've mentioned that it's not a complete node. It only makes the spiral shape and the base.
I couldn't find an easy way to automate the loft and trim process, So, Left it incomplete like you see.
Although, It is possible to do the rest manually.
After applying the node, you can join all pieces and loft the step area.
For me, the tricky part was to make a tangent line on top of the spiral.
This is how I'm doing it:
Make a construction line on the top of the spiral in the right viewport, (tan-int) Then draw a line on it.
In the top viewport, make a copy of this line and use the "loft" command to make a cutting surface.
Then, trim the spiral shape and cutting surface.
11164.21 In reply to 11164.19
Hi Brian
If you have the same result with Barry's, you've replaced it correctly.
"Sweep" node is inside the "Construct.js" file. (Line 28)
11164.22
Salut,
So, with a little perseverance, I've arrived at a result that suits me as far as the shape of a chocolate candy mold is concerned (even if the dimensions aren't exact - I couldn't find anything on the web!).
My problem with the proposed solutions was the connection between the rising curve and the upper part. But Barry's and RebuildSurface's suggestions were a great help.
- Zooen
Show messages:  1-5  6-22
