Face Orientation and Converting 'Joined srf' to Solid in MoI
All  1  2-4
11162.2 In reply to 11162.1
Thank you. I believe I've resolved the issue. Although I haven't tested it on my main project yet, I'm confident it will work.
By using trim instead of projection, I managed to create an indented design.
I realized my mistake was performing a boolean operation on the "Joined srf" which was obtained by the trim operation. By keeping a copy of the solid and performing the boolean operation on that, I was able to get a solid.
Since I was able to get a 'Solid', I shouldn't have any issues with the orientation of the faces anymore. I will confirm this in my upcoming checks.
11162.3 In reply to 11162.2
Hi marzRX, yes if you form your object as a closed solid then it will automatically orient the normals towards the outside of the solid.
Usually it is easiest to cut a solid using boolean difference with another solid as the cutting object instead of Trim. Trim is more of a low level operation, booleans are kind of like a batch mode where they combine trimming and automatically discards pieces based on what volume they are contained inside of and then automatically joined as well.
11162.4 In reply to 11162.3
Thank you, Michael. I was able to create it.
I wondered if I could represent a design from a certain Photoshop tutorial on YouTube in 3D, so I decided to give it a try.
https://www.youtube.com/watch?v=LMIb0K96uYE
MoI is a savior for me. The results that can be obtained through study are excellent, making the whole process very enjoyable. ;)
Show messages: All  1  2-4
