Gear script?
All  1  2-4
11160.2 In reply to 11160.1
Likely the underscore before the *.js and *.htm files, as documented elsewhere on the forum ???
Where/how did you install (and try to activate) the two files?
11160.3 In reply to 11160.1
Hi Matadem, the error is titled "Windows Script Host", so it looks like you are double clicking the RotateAxis2.js file inside of Windows File Explorer.
You can't run a MoI script that way, to run it you need to go inside of MoI and either set up a shortcut key with RotateAxis2 as the command for the shortcut key, or you can type in a command name in the XYZ input box by pressing the Tab key and then type RotateAxis2 and then press Enter.
11160.4
@Bemfarmer...just dragging it into the commands folder...
Michael you are correct...lot of no sleep hours lol.
It works.
Thank you!
Show messages: All  1  2-4
