Creating 'planar' surface on 3d plane
All  1-3  4-7
11156.4 In reply to 11156.1
So the 2D profile curves would be like this.
One 2D profile in the Top view like this:
The other 2D profile in the Front view like this:
Here both shown in the 3D view:
Extrude one of the 2D profile curves out to make a base sheet:
Trim using the other 2d profile:
This generates the best quality surface where the underlying surface is very regular and has no pinching.
So the nonplanar 3D curve is generated by a trim or boolean instead of trying to start with it.
It can usually save some steps and be more convenient to work with solids - extrude the Top profile to make a solid cyllinder and then cut the cylinder with the side profile as the cutting object. That will also generate a trimmed extrusion for this surface but it will already be all connected up to surrounding surfaces instead of just being a single isolated surface.
11156.5
Thank you for the solutions. Just wondering why the planar command can't be made to render nonplanar surfaces like this from a closed curve? I'm also trying to figure out how to cut the 3d closed curve into equal halves, I would have thought a boolean merge with a straight line through the middle would have worked but it doesn't.
EDITED: 23 Jul 2023 by GUYLUKE
11156.6 In reply to 11156.5
Hi GuyLuke,
> Just wondering why the planar command can't be made to render 3d surfaces like this from a closed curve?
The planar command only knows how to build a planar surface which is not what you have here.
I would at some point like to make a method that would automatically reverse engineer the 2D profiles from a 3D curve like this. That will be fairly difficult to make, in the meantime it's better to use 2 2D profile curves to generate it by extrusion and cutting as I showed above.
Usually it is best to work primarily with 2D curves and generate 3D curves as the result of intersections instead of trying to generate a surface from a 3D curve.
Can you please post the .3dm file with the line through the middle that isn't working for you?
Usually Edit > Trim is the thing to use to cut a curve.
11156.7 In reply to 11156.6
Thanks Michael, it's OK I just figured it out using trim.
Show messages: All  1-3  4-7
