Assembling Exploding
All
1-2
3-9
Shamrock
18 Jul 2023 (3 of 9)
11153.3
In reply to
11153.2
Beautiful, thank you kindly that helps and appreciate the quick reply.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Shamrock
18 Jul 2023 (4 of 9)
11153.4
In reply to
11153.3
Also, is there a forum with all commands?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
18 Jul 2023 (5 of 9)
11153.5
In reply to
11153.4
There's a list of all built in commands in reference section of the help file:
https://moi3d.com/4.0/docs/moi_command_reference.htm
There's a section in there for commands that don't have a button in the UI:
https://moi3d.com/4.0/docs/moi_command_reference10.htm#Additional%20commands
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Shamrock
18 Jul 2023 (6 of 9)
11153.6
In reply to
11153.5
Thank you sir,
One last thing is there a way to created multiple viewports?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
18 Jul 2023 (7 of 9)
11153.7
In reply to
11153.6
Hi Shamrock,
You can have 4 viewports visible at once using the "Split" option on the bottom toolbar:
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Shamrock
18 Jul 2023 (8 of 9)
11153.8
In reply to
11153.7
Understood Michael
is there a way to viewport mutliple views for PDF
I would like to set up as 3d view elevation view, section view and plan views all in one PDF. I can in autocad but if i can do in MOi id prefer that instead
Thank u.
EDITED: 19 Jul 2023 by SHAMROCK
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
18 Jul 2023 (9 of 9)
11153.9
In reply to
11153.8
Hi Shamrock,
There isn't currently a built in way for that but there is a plugin for generating curves for 4 views then you can export that.
The plug-in is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-9
