LightShift Script
All  1  2-17
11145.2 In reply to 11145.1
Great work Mo! Thanks.
I like that it doesn't persist between sessions.
Where is that setting changed? Maybe a toggle to set it back to default after fooling around?
11145.3 In reply to 11145.2
Hi BurrMan
I'm glad you liked it.
You can use the "cancel" button, It resets the light direction to before the script is executed.
I think "moi" resets the light direction automatically to (1, 1, -1) every time you open it.
You can use this code to set it back to default:
script:var dir = moi.view.lightDirection; dir.set(1,1,-1); moi.view.lightDirection = dir;
11145.4 In reply to 11145.1
Hello MO,
Your script is remarkable indeed.
The way you can see the detail of your creation is good.
Hope that the next new Moi v5 will have some more script commands that can help more the users who loved 3D MOi.
Thank you for your time and support to this forum.
11145.5
Wow, Very useful script!
Thanks !
11145.6
Hi Ray and Marc
You're welcome.
I'm glad it's been useful for you.
I also find it useful if you use the script alongside other commands. E.g. fillet, blend
You can use this code. It will open the script in a separate window.
The "Done" and "Cancel" buttons become useless though.
script: var sidePaneWidth= moi.ui.getUIPanel('moi://ui/SidePane.htm').document.width; moi.ui.createDialog( 'moi://commands/LightShift.htm', 'defaultWidth:sidePaneWidth,defaultHeight:sidePaneWidth' );
11145.7 In reply to 11145.6
You want to say that your lighting script works in a window, your fillet function in another window, your Blend function in another windows
and all that in the same time ? Or one by one ?
11145.8 In reply to 11145.7
Hi Pilou
Yes, You can run "LightShift" script in a separate window.
Other things work as usual.
The point is you don't need to exit other commands to change the lighting. :)
11145.9 In reply to 11145.8
Perfect i will try that and add it to my French repository! ;)
https://moiscript.weebly.com
Excellent! :)
EDITED: 13 Jul 2023 by PILOU
in my French repository! ;)
https://moiscript.weebly.com/eclairage.html
11145.12 In reply to 11145.11
hi MO
Thanks for you creativity and your sharing
11145.13
Hi Mo,
Great script,
thank you
www.jameselliott.co.uk
11145.14
Thanks MO!
11145.15
Hi everyone
Thanks for your suggestions and encouragement
I've revised about "LightShift" script since my last post.
I thought It's better to use this script as a separate dialog box, so users don't need to exit the running commands.
That made me to rewrite some part of the script and change it a bit.
I've updated my first post and attached "LightShift_Dialog.htm" to it.
Now you can toggle between the default and modified light direction ("Default" button), and toggle the light off or on. ("Silhouette" button)
I prefer to use this version, let me know if I should keep the old version. :)
11145.16 In reply to 11145.15
Love it!
Thanx!
Even works with other custom light styles..
11145.17
Excellent script Mo!
Using this macro for my project add-on graphics when quoting to customers.
Wayne
Show messages: All  1  2-17
