Dim in scripts menu
All  1-6  7-12
11142.7 In reply to 11142.3
Larry, I tried but it didn't change anything for me.
thanks anyway.
- Zooen
11142.8 In reply to 11142.6
Phiro, thanks for the suggestions, I'll give it a try.
- Zooen
11142.9 In reply to 11142.7
> thanks anyway.
You're welcome, but that's odd because the two scripts are quite different with respect to how the list of commands is generated. Max's Scripts.htm used a hard coded list while my Extras.htm generates the list of commands. Did you put Extras.htm and .js in the startup folder & then click on Extras rather than Scripts?
--Larry
11142.10 In reply to 11142.4
Hi Zooen, yes on line number 8 of the script there is an array made of internal command names, it looks like this:
var internalcmd=["CopyClipboardWithOrigin", <....> ];
Add in the things you want removed to this array.
11142.11 In reply to 11142.6
Thank's Phiro,
In the 1st I removed the _ (dash of 8) from the files of Max to restore the alphabetical order in the drop-down menu.
I added, in "Scripts.menu.htm" to var allcmd= [ all the names of the scripts that I no longer wanted to see in the drop-down menu.
As the icons of max (subdiv, bridge, etc.) did not work anymore I looked for the file which was the cause, it was "85 SubdivTools.js", on each line, at the end, it was necessary to delete the _ (dash of 8) of file names.
EDITED: 4 Jul 2023 by ZOOEN
11142.12 In reply to 11142.10
Oops!
Michael, I made my changes in line 11 : var allcmd= ["AddPoint",. But it works (finally now!!...). I guess that's a problem.
See picture.
That's it, I only have the plugins I need (at the moment) appearing in the drop-down menu.
EDITED: 18 Aug 2024 by ZOOEN
Show messages: All  1-6  7-12
