Dim in scripts menu
All  1  2-12
11142.2 In reply to 11142.1
Hi Zooen, can you post the file for your scripts menu?
Probably there is a hard coded list of built in commands that needs to be updated.
11142.3 In reply to 11142.2
Hi Zooen,
Have a look at my Extras menu https://moi3d.com/forum/messages.php?webtag=MOI&msg=10353.1 as an alternative to Max's Scripts menu.
--Larry
11142.4 In reply to 11142.2
The aim is to eliminate from this menu the tools/functions for which I have either an icon available or a keyboard shortcut (often used). I noticed that for some tools that have an icon (for example, BMOI import and export) if I transfer them to the script folder, they no longer work. In green those that I would no longer like to see in the scripts menu.
EDITED: 18 Aug 2024 by ZOOEN
Hi Zoen,
The order of the scripts is alphabetical, but Max's scripts often begin with an underscore which is deleted in the window scripts.
See the names of the files in your script directory.
Have fun !
In the beginning of script.menu.htm, there is a list of commands
I think it's for voiding in the list of scripts the internal scripts.
So, you have to add the new, V5 scripts added as DimXXX to not see them in the script menu.
11142.7 In reply to 11142.3
Larry, I tried but it didn't change anything for me.
thanks anyway.
- Zooen
11142.8 In reply to 11142.6
Phiro, thanks for the suggestions, I'll give it a try.
- Zooen
11142.9 In reply to 11142.7
> thanks anyway.
You're welcome, but that's odd because the two scripts are quite different with respect to how the list of commands is generated. Max's Scripts.htm used a hard coded list while my Extras.htm generates the list of commands. Did you put Extras.htm and .js in the startup folder & then click on Extras rather than Scripts?
--Larry
11142.10 In reply to 11142.4
Hi Zooen, yes on line number 8 of the script there is an array made of internal command names, it looks like this:
var internalcmd=["CopyClipboardWithOrigin", <....> ];
Add in the things you want removed to this array.
11142.11 In reply to 11142.6
Thank's Phiro,
In the 1st I removed the _ (dash of 8) from the files of Max to restore the alphabetical order in the drop-down menu.
I added, in "Scripts.menu.htm" to var allcmd= [ all the names of the scripts that I no longer wanted to see in the drop-down menu.
As the icons of max (subdiv, bridge, etc.) did not work anymore I looked for the file which was the cause, it was "85 SubdivTools.js", on each line, at the end, it was necessary to delete the _ (dash of 8) of file names.
EDITED: 4 Jul 2023 by ZOOEN
11142.12 In reply to 11142.10
Oops!
Michael, I made my changes in line 11 : var allcmd= ["AddPoint",. But it works (finally now!!...). I guess that's a problem.
See picture.
That's it, I only have the plugins I need (at the moment) appearing in the drop-down menu.
Show messages: All  1  2-12
