Moi 5 beta, curve are visible through solids
All  1-3  4-8
11134.4
Hi All trying to change the option view display mesh angle I have tried changing from the default 10 to 5 in the options window - also tried to change it in the ini file and also the template file stored under my user APPDATA location for some reason keeps going back to angle of 10. Is there a security issue for me to be able to change this. Using win 11 with Moi 5 current beta. Any wisdom welcome.
thanks
Alex.
11134.5 In reply to 11134.4
Hi Alex, setting the mesh angle lower than 10 can tend to make very heavy meshes with larger files.
So it won't persist setting it below 10 by default but you can disable the "guard rails" by setting this in moi.ini :
[View]
NoMeshAngleLimit=y
11134.6 In reply to 11134.5
“”””” [View]
NoMeshAngleLimit=y”””””””
This is new? I think i have a “startup” item doing this. Would prefer the ini setting
11134.7 In reply to 11134.6
Hi Burr,
Not too new - it was introduced in V4 beta Oct-27-2020
http://moi3d.com/forum/index.php?webtag=MOI&msg=10011.1
11134.8 In reply to 11134.7
“”””” Not too new - it was introduced in V4 beta Oct-27-2020”””””
Well, i would have bet money that was just a couple months ago!!!
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=9942.11
I’m slipping.
I’ll set the ini file switch now.
Show messages: All  1-3  4-8
