GemCad and GemRay
All  1  2-4
11130.2 In reply to 11130.1
Seems all format files from GemCad are not reloaded by any progs! :(
too old versions!
Not evident prog! :)
Edit
I have found a workaround!
Import the DXF inside the free Pcon Planner! https://pcon-planner.com
Export as OBJ & double faces! (curiously exported as DXF is not reloaded by Moi ! )
_import OBJ... (by Max Smirnov)
EDITED: 19 Jun 2023 by PILOU
11130.3 In reply to 11130.2
DXF files can contain a lot of different kinds of data. MoI's DXF importer is only focused on processing 2D drafting data like lines, circles, arcs.
It is likely that your DXF file contains polygon mesh data in it (which MoI does not process) and not drafting data.
11130.4 In reply to 11130.3
thx for the infos!
Show messages: All  1  2-4
