Facetting bottle
All  1-2  3-7
11128.3 In reply to 11128.1
If the bottle starts life as say a solid cylinder, it could be faceted like cutting a gemstone.
The cutting tool(s) is a plane at specific angles, and each facet is (boolean or trim) cut as desired, and the tool rotated around desired z and x and y axi, for the next cut.
There can be symmetries, so once a basic set of faces is created, circular array, or mirroring, could be shortcuts, merging the faces, and abandoning the cylinder...
EDITED: 19 Jun 2023 by BEMFARMER
11128.4 In reply to 11128.1
Hi Finema,
> What's the best way to facetting a bottle with MOI ?
Probably by using Draw curve > Polygon to create some stations at different z levels to snap on to.
See here for a detailed example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9712.13
11128.5 In reply to 11128.3
I forgot that the bottle should be hollow.
Here are some cylinder intersections to try to model in Moi:
http://paulbourke.net/geometry/cylinders/
11128.7
Thanks a lot all !!!!
Show messages: All  1-2  3-7
