Single script to select different things
 1-15  16-31
11127.16 In reply to 11127.15
Thank you a lot, Michael.
With this, I should have all the pieces I need.
sorry for asking too much.
I appreciate you.
- Flowgun
11127.17 In reply to 11127.13
Some more pieces to use for the 3 separate scripts:
> - one for dealing with objects: selects last-created objects if nothing is selected, otherwise
> looping through named objects (and it wouldn't matter if they are curves or not)
Nothing selected is detected like this:
var selected_objs = moi.geometryDatabase.getSelectedObjects();
if ( selected_objs.length == 0 )
Selecting last created objects is: moi.geometryDatabase.selectLastCreated();
Stepping through named objects is the chunk of the script above that follows this:
/* If a named object is selected, deselect it and select the next one */
> - one for selecting edges (naked edges or edge loops / boundaries)
Selecting naked edges is the part of the script above with:
/* If surfaces are selected, select their naked edges */
Selecting edges of a face is this part:
/* 1 face selected, select edges of face */
Loop selection is this part:
/* If any edges are selected do loop selection */
> - one to select curves: it would loop through selecting open curves, closed curves, and all curves. even if nothing is selected.
Selecting all curves is the part marked with this:
/* If nothing selected, select all curves */
to select just open or closed curves, that would be like this:
var curves = moi.geometryDatabase.getObjects().getCurves();
for ( var i = 0; i < curves.length; ++i )
    var crv = curves.item(i);
    if ( crv.isClosed )
        crv.selected = true;
11127.18 In reply to 11127.17
Here's what I came up with for now. It's not perfect, but still very useful:
script: var selected_objs = moi.geometryDatabase.getSelectedObjects();
var all_objs = moi.geometryDatabase.getObjects();
var done = false;
	/* If nothing selected, select last-created object */
	done = true;
else if ( selected_objs.numBReps > 0 )
		/* If only joined surfaces are selected, select their naked edges */
		selected_objs.setProperty( 'selected', false );
		var breps = selected_objs.getBReps();
		var allNaked = true;
		for ( var i = 0; i < breps.length; ++i )
			var brep = breps.item(i);
			if (brep.getNakedEdges().length == 0)
				allNaked = false;
		if (allNaked)
				var naked = brep.getNakedEdges();
				if (naked.length> 0)
					naked.setProperty( 'selected', true );
			done = true;
		else
			selected_objs.setProperty( 'selected', true );
/* If some points on a curve are selected, select the rest */
if ( !done )
for ( var i = 0; i < all_objs.length; ++i )
	var obj = all_objs.item(i);
	if ( obj.isCurve && obj.hasSelectedEditPoints ) /* this only works in latest versions */
		moi.geometryDatabase.selectAll();
		done = true;
		break;
if ( !done )
	var objects = [], name_index = [];
		var name = obj.name;
		if ( name )
			if ( name_index[name] == undefined )
				name_index[name] = objects.length;
				objects.push( [] );
			var index = name_index[name];
			objects[index].push( obj );
	function sortfunc( a, b )
		var a_name = a[0].name;
		var b_name = b[0].name;
		return a_name.localeCompare(b_name);
	objects.sort( sortfunc );
	var index_to_select = -1;
	for ( var i = 0; i < objects.length && index_to_select == -1; ++i )
		var obj_array = objects[i];
		for ( var j = 0; j < obj_array.length && index_to_select == -1; ++j )
			var obj = obj_array[j];
			if ( obj.selected )
				var any_unselected = false;
				for ( var k = 0; k < obj_array.length; ++k )
					if ( !obj_array[k].selected )
						any_unselected = true;
						break;
				if ( any_unselected )
					index_to_select = i;
				else
					index_to_select = (i+1) % objects.length;
	if ( index_to_select != -1 )
		moi.geometryDatabase.deselectAll();
		var obj_array = objects[index_to_select];
		for ( var i = 0; i < obj_array.length; ++i )
			var obj = obj_array[i];
			obj.selected = true;
		done = true;
if ( !done )
	if ( selected_objs.numStandaloneCurves> 0 )
		/* If some curves are already selected, we loop through curve selection. */
		var allSelected = true;
		var closedCurves = true;
			if (! crv.selected)
				allSelected = false;
				if ( crv.isClosed)
					closedCurves = false;
		if (allSelected)
				if (crv.isClosed)
		else if (closedCurves)
				if (! crv.isClosed)
		else /* select all */
			curves.setProperty( 'selected', true );
	else if ( selected_objs.length> 0 && selected_objs.numFaces >= selected_objs.length )
		/* faces selected, select the edges of the faces */
		for ( var i = 0; i < selected_objs.numFaces; ++i )
			var face = selected_objs.item(i);
			face.selected = false;
			face.getEdges().setProperty( 'selected', true );
	else if ( selected_objs.numEdges> 0 )
		moi.geometryDatabase.selectLoop();
// - Flowgun
Edited by Michael - convert // comments into /* */ and add a couple missing semi-colons so it can work pasted into a single line as a shortcut key.
EDITED: 14 Jul 2023 by MICHAEL GIBSON
11127.19 In reply to 11127.18
Hi Flowgun, thanks for sharing it. I edited your post to put it inside of <code></code> so it would show tabs.
11127.20 In reply to 11127.19
With this script one can select loop of edges?
How about edges that are connected to a face?
I should assign a short key to this script, if I want to use it?
- Psygorn
11127.21 In reply to 11127.20
Hi Psygorn,
It looks like it is set to select a boundary loop if you have edges selected before running it.
Looks like if you have faces selected it will select the edges of the face.
Yes set up a shortcut key under Options > Shortcut keys and copy/paste in the above script for the "command" part of the shortcut key.
11127.22 In reply to 11127.21
I did what we usually do to assign a short key to MOI commands/scripts but I get this massive Error!
I want to have the effect you can see here: https://www.youtube.com/watch?v=9DBqE_CX7Zo (after 0:55 of the video you can see my desired effects; How can I have these? )
- Psygorn
11127.23 In reply to 11127.22
Hi Psygorn, there were a couple of things in there that was preventing it from working when pasted into a single line, try getting it again.
11127.24 In reply to 11127.23
I tried getting it again and it works (No Error now)
But I cannot replicate the effect in the YouTube Video I sent to you earlier!
For example when I have a face selected it cannot select edges that are in contact with the selected face!
I am using this script for a long time now it selects edges of a selected face "script: /* Select edges v1.4 */ var gd=moi.geometryDatabase, so=gd.getSelectedObjects(); function ss(o,v){o.setProperty("selected",v)} function sl(o){ for ( var i=0; i<o.length; ++i ) o.item(i).getEdges().invertProperty("selected");} gd.selectLoop(); sl(so.getFaces()); sl(so.getSolids()); sl(so.getOpenBReps()); sl(so.getSingleFaceBReps()); ss(so.getBReps(),0); ss(so.getFaces(),0);"
But I want to have more than that and be able to select edge loops as well as corner edges (like the YouTube video) I appreciate your help in advance :-)
- Psygorn
11127.25 In reply to 11127.24
Hi Psygorn,
That's working ok for me over here. For example when I have this face of a box selected:
When triggering the script it results in this edge selection:
If you're not able to get that result, can you please post your moi.ini file so I can see if you've got the entire script in there? You can find your moi.ini file's location by going to Options > General > "Edit .ini file" button. A dialog will pop up and show you the location of the moi.ini file.
11127.26 In reply to 11127.25
I want this effect:
and this one:
In a YouTube video which you can find it here: https://www.youtube.com/watch?v=9DBqE_CX7Zo it is mentioned in MOI V5 there are new features and from 00:55 seconds afterwards the above features are shown!
I saw the video and I thought I would want those features too. So, I reached out to you. :-)
- Psygorn
11127.27 In reply to 11127.26
Hi Psygorn, what you show there are not new features for MOI v5, they are features of some scripts that the person making those videos has made.
You'll need to reach out to them, those are not built in functions in MoI as of yet.
11127.28 In reply to 11127.27
Oh, Ok :-)
Thank you.
- Psygorn
11127.29 In reply to 11127.28
It's external plugings like the Max Smirnov like! ;)
11127.30 In reply to 11127.28
Hi Psygorn,
The corner edges plugin is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11063.1
The tangent propagation shown in the video is probably using "_ExpandSelectionTangecy" from here:
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=8665.195
- Peer
11127.31 In reply to 11127.30
Thanks PEER,
- Psygorn
Show messages:  1-15  16-31
