Scripts by Dead_wall !
All  1-3  4-5
Here the automatic translation of the "read me file" ! :)
No special problem to load the file and unrar it...
Here the files : https://moiscript.weebly.com/uploads/3/9/3/8/3938813/m3dch_1.500_v5_beta.rar
Ps I have not install it just see what are them...
Pilou so...
Read me file
Hello dear friend. You have received in your hands the MOI3D Ceran Helia Edition program for v5, hand-picked and lovingly assembled.
Ceran Helia means freedom and limitation, rotation and identification.
Ceran Helia gives the answer to all questions, about the important thing, how to get out of the circle, and be yourself.
Tseran Helia is the realization of the inner self when the fucking mo3d can't perform a fillet because you fucker didn't look behind the seam.
Ceran Helia is inspiration from simple shapes that you can twirl, and be twirled.
And finally, Ceran Helia is something that can spin you day in and day out...
Aki Plyushkin has taken the crap out of the forum:
- Worth noting is the new color palette, pleasing to the eye, for those who like to poke around at night. Every pixel is rendered, so if you want to change something better put up with it)
- Sorted out all the unnecessary and necessary crap from the script commands and dialogs.
- Adapted the most useful commands for quick access, such as CmdFider, CmdHistory and others...
- IMPORTANT: CmdFider and CmdHistory only work as intended when both are open. Command history and Fider are only written to history if the history window is open.
- I've written in tandem with JS spekt, a new script to sort shortcuts from ini file, by pressing ctrl shift alt modifiers.
- Changed panels, all of them. Added ability to unstick literally every button into separate window.
- Reworked obj library, from scratch rendered all the icons, and added a guide to add your own libraries. But the guide is a bit crooked, so it's easier to ask me)
- Sorted out the current commands in the interface, so now the draw panel has functions to create ABSOLUTELY all types of objects in my3d.
- There's a bunch more, but there's a fuckload of omissions. If you have any questions, I advise you to contact me directly in my telly (t.me/moinepomoi) or on e-mail (denwerdan@mail.ru)
!!! IGNORE THE BEGINNING OF THE VIDEO TUTORIAL WHERE I DOWNLOAD MY3D TRIAL, THIS IS NOT THE VERSION OF THE PROGRAM !!!
Get access to the beta http://moi3d.com/forum/index.php?webtag=MOI&msg=11056.1
All you need to do is shove the Moi 5.0 folder into C:\Program Files\<yourMoi3d folder>\.
Drag the contents of the MOI folder into %appdata%\Moi. The shortcut to the appdata is in the same folder.
The default configuration file will be the one next to the executable (moi.exe).
It is possible, but not obligatory, to move MOI.INI to %appdata%\Moi
If that doesn't work, try C:\Users\Username>AppData\Roaming\Moi
Make sure that MOI.INI is either in %appdata% or in the root of the program.
For the bridge with Rhino7 put URC.exe file on the drive C:/
Additional information about the installation on the mac:
1) Put the MOI folder in Recources: Programs - > MOI -> Show Package Contents -> Contents -> Recources.
2) MOI 5.0 folder in User / Library / Application Support / Moi. By default, the folder Library is hidden, not visible. The folder Library is called via the menu FINDER -> press OPTION and click on GO TO and the folder Library appears.
Love this building as I do, and you will always have a decent wage.
Change List 1.500 19.05.23
- Revision change to v5
- 3 new kitbash (Pipe&Pumps, Screw, ControlPanel(in process)) + update for old ones (Bulgarov, PCB).
- Added M3DCH_White light theme (in process).
New commands:
- QuickTrim - command allows you to cut curves that intersect.
- Eraser - creates a circle in the radius of which the Boolean Difference does.
- MatchAnnotationProps - Equalizes your annotations with the selected annotation example.
- NimbleNudge - Updated Nudge script. Moving objects around the scene is now easier and more intuitive.
- CVolume3 - Updated volume script. Materials list updated.
- CornerEdgesOfFace - Selects sharp edges from the selected surface, imitating RingSelection.
- ExtendTangecy - New improved LoopSelection.
- New Rectangle - There are two new shortcuts D - Boolean and R - rounded edges.
- PolyCut - Cutting off parts of objects.
- New Fillet, Offset, Shell, Inset - The method allows you to increase/decrease values on numpad in real time.
- FlowExtendetSrf - allows to extend surfaces relative to their curvature.
- UVchanger-plane - A script that can rotate UV surfaces. great for fixing curved surfaces from plasticity.
- And many other things I added as I went along.
List of changes 1.471 12.11.22
- Slightly lost with the visuals of some interface elements.
- A lot of work was done for reference. Thanks to the guys who volunteered to help with the editing. Conditionally the help is ready at 81%.
- Added UVchanger script. Added it a long time ago, I don't remember(
- A lot of minor fixes.
Changes list 1.458 29.08.22
- In the command bar, corrected the incorrect display of shortcuts in snapping.
- There is also added a command-set button for cameras. Where "Get/Set Camera" is old camera functionality. It opens in a new window, where it works as before. "ViewManager" command that allows you to save camera views in your project (it is important that the project is saved, then the views will also be saved next to the project file). "Align3DViewToSurface" command aligns the camera relative to the plane you selected.
- Commands that have additional functionality on the right mouse button now change the cursor into a contextual state.
- Updated help files for the Draw and Edit commands. For commands that do not have context, help is invoked by pressing Shift+Click.
- Added a new command to create square spirals.
- Minor fixes.
Changes list 1.44 09.08.22
- Styles have been fixed in the Image menu.
- When importing/inserting, you can now quickly select the multiplier for the scale of the model.
- New.3dm file now connects from the MOI shared folder
- The RotateAxis function can now rotate an object along the axis of the selected projection. You only need to select the same point twice in 2D projections.
- The command set now reacts when it is expanded. This is done for convenience, to make it visible that the commandset is open.
- Wrote a tipix for the "calculators" in the command bar and in the other instances. To enlarge the gifs in the tipus, you can just expand the window.
- Finished the command bar a bit.
- Minor fixes.
Changes list 1.4 25.07.22
SIDEBAR:
- Added button to disable shortcuts. It remembers the selected state. Shortcuts are not disabled inside the menu.
- The shortcuts are prescribed for each command in plain sight. Special thanks to Oleg Krasnov (https://www.behance.net/krasnovpro) for his help.
- The principle of opening command sets has been changed, now you can easily get to the right command.
- The old way of opening commands can be replaced. In the /ui directory is the same file, which you can simply replace.
- To open the menu in a separate window, you can triple-click the RMB on the icon.
- The commands will now have a help and typeset. So far only for the first tab.
- Added alternative RMB commands for most commands.
- Expanded Select menu.
- Added Add tab.
- The SubD tab now has two command types. Native v4 and Subdiv_beta9/Classic.
- Never press the clock.
- Most of the commands have been redesigned and updated for v4.
- For circles, there is a new CurvatureCircle command.
- For rectangles, there is a new command called Slot.
COMMAND PANEL:
- Now there are shortcuts here too, and they are disabled in the same way as in the sidebar.
- In the File menu, the principle of import has been changed, now the command at the end of the import offers to change the size of the model.
- An incremental save command has been added.
- The Ctrl+Space shortcut is used to change projection views. To invert projection views Ctrl+Shift+Space is used.
- To activate Align, use Shift+Alt+Arrows on the keyboard. Double-clicking the arrows while Shift+Alt is pressed activates Alight in the selected direction. In the Align command itself, when active, you can use the WASD and QE keys to switch directions.
- In the process of refining ObjLibrary, the main change is the insertion of an object followed by its size. Also by pressing Shift+Alt+S you can call a separate library window in order to import many objects at once. And there is also a refresh button to immediately see the added model.
- Added library sort buttons so that you don't have to scroll 1000 years to the folder you want.
- Kitbash models are now 196, special thanks to Toly Voziakov (http://www.artstation.com/tolja-an) for the TOLYAN kitbash.
- New types of lighting have been added to Lighting.
- Reassigned the original help styles to the build theme.
CONTENT BROWSER:
- Added Expand button, to hide overly long panels.
UPPORTS:
- ViewControl updated. Added ability to enable viewport acceleration.
- Added an option to display views for ortho-projections.
- Button for on/off display of hidden lines was brought out, and RMB can be used to turn on/off display of lines for selected models.
- S key centering the projection closest to the camera, Double press S to toggle the projection closest to the camera.
- The D key locks object movements along any selected Straight snap axis.
- In the options there is an option to display on the Y grid and choose its color.
OTHER CHANGES:
- A new appearance of the commands is being finalized.
- Most commands have isolated shortcuts, for example, the active Move command has 6 shortcuts.
- The number of commands was reduced to 333.
- The number of scripts was increased to 217.
- Improved icons.
11113.5 In reply to 11113.4
Thanx!!
Show messages: All  1-3  4-5
