Sweep hmmm´
All  1-7  8-14
DelCorners is a script done by Max Smirnov
You can find in here http://moi3d.com/wiki/MaxScriptArchive
11106.9 In reply to 11106.8
Thx phiro!
I cannot initiate it. Thought it would work like for example Tab - rebuild command.
I took both files into the command folder. But I´ve got that message...
(I do not often implement the scripts...)
11106.10 In reply to 11106.9
you must install the plugin! ;)
Normally 2 or one files to unzip if they are zipped (named by their command functions) to install in the Moi folder commands
11106.11 In reply to 11106.10
It is one zipped folder, with two files.
I put the decompressed files into command folder. As I mentioned before.
Something wrong here?
Is it a plugin or a script? I got the message: Command DelCorners not found. Might be a plug-in is not installed"
And is a script initiated with the tab or as a command with, in my case ctrl+D...
EDITED: 25 May 2023 by MALA
11106.12 In reply to 11106.11
Hi Mala, I don't remember exactly why but many of Max's scripts begin with an underscore "_" character at the start.
If you look closely at the files that you are copying you'll probably see they are actually named _DelCorners.htm and _DelCorners.js - note leading underscore _ character.
So when those files are copied into MOI's commands folder there will be a new command named _DelCorners available to use. The name you are using is missing the underscore _ character. That's why you're getting the error.
11106.13 In reply to 11106.12
“”””””” I don't remember exactly why but many of Max's scripts begin with an underscore "_" character at the start.”””””””
It was used by the custom UI mechanism to separate out his commands from native commands.
The custom UI can read the underscore for grouping/display.
11106.14
Yes it was the: _
Thanks for the impulse and helps!
Show messages: All  1-7  8-14
