Sweep hmmm´
All  1-11  12-14
11106.12 In reply to 11106.11
Hi Mala, I don't remember exactly why but many of Max's scripts begin with an underscore "_" character at the start.
If you look closely at the files that you are copying you'll probably see they are actually named _DelCorners.htm and _DelCorners.js - note leading underscore _ character.
So when those files are copied into MOI's commands folder there will be a new command named _DelCorners available to use. The name you are using is missing the underscore _ character. That's why you're getting the error.
11106.13 In reply to 11106.12
“”””””” I don't remember exactly why but many of Max's scripts begin with an underscore "_" character at the start.”””””””
It was used by the custom UI mechanism to separate out his commands from native commands.
The custom UI can read the underscore for grouping/display.
11106.14
Yes it was the: _
Thanks for the impulse and helps!
Show messages: All  1-11  12-14
