Blender to Moi extension
11101.1
Quick question which format does one use to export from Blender to Moi3d ?
I use fbx from Moi to Blender but vice versa I do not know.
Thank you!
11101.2 In reply to 11101.1
Hi Matadem, It depends on what type of object you have created in Blender.
If you have constructed a polygon mesh object there, that's typically not suitable for transfer into Moi, because that type of object is made up of a lot of little flat facets and not smooth surfaces like MoI is designed to work with.
There is some description of this in the FAQ here:
https://moi3d.com/faq#Q:_Why_can_I_export_to_.obj_format.2C_but_cannot_read_.obj_format_into_MoI.3F
If you have created a sub-d object in Blender, that type of object can be brought into MoI by exporting its control polygon cage to .obj or .fbx format and using SubD > Create > "From file" in moI.
EDITED: 20 May 2023 by MICHAEL GIBSON
11101.3 In reply to 11101.2
With FreeCAD you can import the OBJ and with the "Workbench part" convert it in part with the command create shape from mesh, and then save the file by exporting the selections as a STEP and import your reference in Moi3D.
this is an example of poly obj with triangles, convereted and imported.
Imported Step in Moi3d
FreeCAD_mesh to part
but be careful because if the mesh is too dense you will have problems.
Greetings
11101.4 In reply to 11101.1
This is a direct bridge to blender I use and it works great.
https://github.com/TitusLVR/BMOI_Connector
Barry
11101.5 In reply to 11101.4
@Barry
If an object's modification is made in one prog does it "mirroring" automatically on the other prog ?
A sort of permanent link...
11101.6 In reply to 11101.5
No it doesn't.
Barry
11101.7
Thanks to all...
I have the BMOI export import installed ...but I need to install it in Blender as well....going to give it a try..
Subd create works as well!
Where can I get this Moi theme?https://camo.githubusercontent.com/7a24fdd0b706b5df981634b5e30a92b1fda64e9c51441120dc8a598f5675d9b9/68747470733a2f2f692e696d6775722e636f6d2f736a4c50336b382e6a7067
Looks awesome dark greenish?
Thank you!
EDITED: 20 May 2023 by MATADEM
Size: 35.3 KB, Downloaded: 112 times, Dimensions: 345x294px
