Moi and Blender (Grouping to render question)
All  1-3  4-8
11090.4
Both methods work.
Question what is the difference between naming object and assign colors.
The reason I ask because I tried importing a drawing with different parts into sheetcam and I expected it since they were named differently for
each part to get its layer.
Only when I assigned them different colors it imported with different layers.
Thank you!
11090.5 In reply to 11090.4
No difference I believe :) And the even be blended! :)
Different objects can have a same colors ...colors are works' color
Different Object can have a same name but it's not very clever because they will be in the same "Name" in the Outliner!
This can be used of course if wanted for any reasons!
Many crossing selections can be made!
11090.6 In reply to 11090.4
Hi Matadem,
The object names will affect the structure of the Outliner / Scene Collection browser thing in Blender. The combined objects will behave as one entry there.
Style assignments will affect the materials list and the materials assignment.
If the main thing you want is for several different objects to have the same render material, then probably use style assignments. Then when you're in Blender you will have separate objects but they will be assigned a single material and you can edit the materials.
11090.7 In reply to 11090.2
I was keenly interested in this as I frequently run into this issue when exporting as an OBJ to import into Blender or 3D Coat.
However when I export as an OBJ in MOI I do not see the option you mention (Import/Export > "Combine same named objects" (checkbox at the top)).
Ken
11090.8 In reply to 11090.7
Never mind, I found it in the application Options setting as Michael suggested. I thought he meant options in exporting.
Sorry...
Show messages: All  1-3  4-8
