Asynchronous factories (scripting)
All  1-2  3-7
11087.3 In reply to 11087.2
Thank you Michael for your thorough and speedy answers to my questions! I wouldn't have guessed that I could run any factory asynchronously or that .calculate() forces execution on the main process even for "async factories" except when the new 'async' option is passed.
I'll add all this to the API doc.
- Peer
11087.4 In reply to 11087.3
Hi Peer,
re: this part
Sorry I didn't mean to imply this part, factories will only do an async .update() if they are internally marked with a "do async updates" flag.
What I meant was that the .waitForAsyncUpdate() wasn't implemented just on those 3 particular factories, it's part of the base geometry factory interface.
If you call .waitForAsyncUpdate() when there is not an async update currently in progress it should just be a NOP.
11087.5 In reply to 11087.4
I was thinking that factory.waitForAsyncUpdate() causes the factory to be processed remotely, but now I'm thinking that it does exactly what the name implies: waits for some event that occurs when an already-running remote process finishes.
It sounds like there are "async factories" that are processed remotely by default when doing factory.update(), like ArrayGem and Twist, and that it's necessary to do factory.waitForAsyncUpdate() after doing factory.update() and before using the results from the update of an async factory.
But, if an async factory is run with factory.calculate() then it will run on the main process rather than remotely.
However, any factory, including async factories, can be processed remotely by doing factory.calculate( 'async' ) and in that case factory.waitForAsyncUpdate() shouldn't be used as the next line in JavaScript, because factory.calculate( 'async' ) is already waiting internally for the remote process to finish.
- Peer
11087.6 In reply to 11087.5
Hi Peer,
Correct.
Yes, this is because factory.calculate() returns an object list to the caller.
Yes, for a while I had this turned on automatically for async factories but it caused some compatibility problems with some of Max's more complex scripts that had timers that can get reentrantly called during the internal waitForAsyncUpdate(). So it's opt-in now.
11087.7 In reply to 11087.6
Thanks for straightening me out Michael and for explaining some of the reasoning behind this setup.
- Peer
Show messages: All  1-2  3-7
