Geometric Curiosity!
All  1-2  3-12
11083.3 In reply to 11083.2
Triangles with sides of 1,2,3,4,5, and sqrt(5) and 2* sqrt(5)?
Golden ratio?
710 77345
11083.5 In reply to 11083.1
Hmm, an interesting puzzle Pilou! Needs some clever rounding of dimensions to achieve these results. ;-}
For example, I drew the square sides to length 2.24*2 and did not achieve the even 1, 2, 3, 4, 5 sides of the triangles. Then I drew the square with sides 2.238*2, and at least with 1.00 display rounding was able to achieve the same image.
--Larry
Hi Larry,
You're right, but 2.24 is not the real size because it's sqareroot of 5.
Squareroot of 5 is 2.2360679775...
But Moi can help you...
If you give the exact value to Moi (2 times squareroot of five), the job is done...
Give the size as 2*sqrt(5) and MoI will understand it !
The documentation explains it :
Any of the functions on the JavaScript "Math" object are available for use, including: sin(), cos(), tan(), sqrt(), pow(), round(), random(), the constant PI,
and also rad() which takes a parameter in degrees and returns it in radians, and deg() which takes a parameter in radians and returns it in degrees.
Even if you show 7 decimal places, it gives you the right distance.
Thanks to Magic Michael !
EDITED: 3 May 2023 by PHIRO
11083.7 In reply to 11083.6
Thanks Phiro!
I didn't recognize the 2.24 as the square root of 5...such an error deserves the scorn of Pythagoras given the context! Now I can better appreciate Pilou's curiosity! :-)
--Larry
Of course i had only 2 decimal points for a more clear presentation! ;)
And it's more easy to remind round square root of 5 for speed estimation like 2.4
than 2,2360679774997896964091736687313... :)
11083.9 In reply to 11083.4
I had to Google search Burrman's numbers. :-)
11083.10 In reply to 11083.9
“”””” had to Google search””””
Forgive me for wasting your time B.
At least i left out the long story and math calcs we used to provide to get to the answer!!!
11083.11 In reply to 11083.10
I particularly enjoyed the story of a person ordering a 710 cap at the auto parts store!
EDITED: 4 May 2023 by BEMFARMER
Show messages: All  1-2  3-12
