Surface Blend G1 -> G0 not possible?
All  1-3  4-9
11071.4 In reply to 11071.3
Hi rhinouser141,
Welcome!
I think there are a couple methods that might give the results you want.
Here I drew some little stubby lines using Draw Curve > Lines coming off the plane to determine the angles at the G0 side. It's easiest to draw the lines after setting up a construction plane aligned with the plane by doing View > CPlane.
I then did 4x blends between the 4 ends of the 2 semicircles and the 4 stubs and Edit > Joined the stubs and blend curves to get rails for Construct > Sweep.
Finally I picked an edge curve as the object to sweep and the upper and lower rails in the second step.
- Peer
11071.5 In reply to 11071.3
Hi rhinouser141,
See .3dm attached
Another method is Construct > Network where a net of curves is drawn first:
And then they are all selected as the input to Construct > Network:
And finally maybe the most direct method is to use Construct > Blend after first drawing a little stub of a plane at the G0 side:
One way of drawing the stubs is to do Construct > Extrude on an edge curve of the large plane, click Set Dir, and then pick 2 points to set the extrusion direction. A temporary construction line might be useful here.
- Peer
EDITED: 17 Nov 2024 by PEER
11071.6 In reply to 11071.5
In the last method what must be the angle / & direction of the little extrude for have a G0?
Other method but not sure of the G0... last blue surface is a sweep with edges and the 2 Blended curves
EDITED: 20 Apr 2023 by PILOU
11071.7 In reply to 11071.5
Hi 'pressure' :-)
Thank you for your time and tips.
Best regards
11071.8 In reply to 11071.7
Yeah, i always temp extrude the G0 edge in the normal tangent direction away from the blend. Then do my blend and delete the temp surface.
We are waiting for multi directional blending and setting curvature for each edge within the command.
11071.9 In reply to 11071.8
Hello BurrMan,
clever workaround !
Best regards
Show messages: All  1-3  4-9
