Loft ?
All  1  2-5
11070.2 In reply to 11070.1
Hi prince,
> Is there anyway that i can do a loft with guid curves in moi3d ??
MoI has a function called "Sweep" that makes a surface using profile curves and rail guide curves.
Check out the part labeled "Two rail sweep" here:
https://moi3d.com/4.0/docs/moi_command_reference7.htm#sweep
11070.3
Hi Michael ,
That's true its exactly the same
sweeping with multiple rails is what i need
i got lost in surfacing of a car model and i forgot about it while i was trying to do a part with a loft
Thank you so much Micheal
11070.4 In reply to 11070.3
Hi prince, there is also a Network surface command as well which can be similar:
https://moi3d.com/4.0/docs/moi_command_reference7.htm#network
11070.5
Hi Michael ,
Thank you so much
All my surfacing was done with it ( the network )
But sometimes it get a bit tricky when i nedd to get a sufrace between 5 curves ( network fail in some of these ) , so i need to trim or join some curves to get it done with 4 curves
from what i experienced ( the surface is done very well when you do it with 4 guided cuves ) .
Thank you again
Show messages: All  1  2-5
