How to scale only face?
All  1  2-10
11067.2 In reply to 11067.1
If it's a "primitive"
Show Points
Select them and scale them!
EDITED: 18 Apr 2023 by PILOU
Else more tricky for any volumes using the Flow Function!(2 steps here)
avantage of the Flow Function ...you can enable Histo !
So...
or more elaborated... https://vimeo.com/370146519
Flow_Factory from danperk on Vimeo.
11067.5
Thank you, this is excellent.
11067.6
I need ask to one more question.
How i can make edge loop, i need extrude only that half of that face.
11067.7 In reply to 11067.6
Hi Robert,
Draw in a line across the face, select the face and run Edit > Trim. At the prompt to select cutting objects select the line and push Done or right click in a viewport. At the next prompt to select which pieces to discard press Done or right click in a viewport to leave all pieces behind.
That should trim the face into 2 faces, select the half you want and then run Construct > Extrude.
11067.8 In reply to 11067.6
11067.9 In reply to 11067.7
Yeah, that's it.
Thank you guys, youre the best. : )
11067.10 In reply to 11067.9
Don't forget to kill the line cutting...after trimming...if no need...
(or enable Delete Cutting Objects) in the Trim function
Show messages: All  1  2-10
