Boolean diff anomaly ?
All  1-4  5-9
11064.5 In reply to 11064.4
Hi Sven,
> Flow can result in difference results running without changes to what is being flowed ?
The flow result is dependent on where you click on the base surface and target surface.
If you click in different areas that can give different results.
You need to click near the corner of a surface but not quite exactly on the corner, a little bit along one edge as described here:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
Looking at the file I think the self-intersections are in the B letter here:
11064.6 In reply to 11064.4
And there's a little zig zag in the I that would be good to get rid of too:
11064.7 In reply to 11064.4
Hi Sven, try the boolean with this attached version, it should be ok now.
I edited the curves in those 3 spots, 2 on the "B" and that zig zag which is only on one I it seems?
EDITED: 16 Apr 2023 by MICHAEL GIBSON
Message 11064.8 deleted 16 Apr 2023 by WN
11064.9 In reply to 11064.6
Wow. I now see how carefully one needs to look at these things. Thanks for showing the actual problem areas. Helps explain where the flow stopped working so that should have been the area where I started looking for problem. Learning. Thanks Michael
Sven
Show messages: All  1-4  5-9
