Hi Michael. Thanks for the insights, always helpful. The font curves have been extruded so there should be adequate overlap. I looked at the vector letters a bit looking for something that could explain, but don't see anything. Flow can result in different results without changes to what is being flowed ? I've uploaded the .3dm file to google drive below.
Wow. I now see how carefully one needs to look at these things. Thanks for showing the actual problem areas. Helps explain where the flow stopped working so that should have been the area where I started looking for problem. Learning. Thanks Michael
