selecting multiple edges for filleting script
All  1  2-7
11063.2 In reply to 11063.1
Thanks for the new selection undo commands. Those are working great here.
Currently this script only selects the outside corner edges of a face. In other words, corner edges that intersect with the outer edge loop. It might be nice if each edge loop could be targeted independently. Kind of like how surface/surface flow is sensitive to where I click on the face or maybe like curve.clickSelectionPoint, but for a face. Is there something that could be used to get the edge closest to where the face is click selected?
- Peer
11063.3 In reply to 11063.1
So not working for the little hole on the the top surface ?...
Can it works on some objects / Volumes in the same time ?
11063.4 In reply to 11063.3
That's right Pilou. It doesn't work for holes.
It works one face at a time, but those faces can be of different solids. Are you saying that it would be useful if it could operate on multiple faces at a time?
- Peer
11063.5 In reply to 11063.4
yes selecting some faces of some objects then call the plug... :)
But maybe some hard to code ...
11063.6 In reply to 11063.2
Hi Peer,
There isn't a script accessible method on a face for getting the click selection point like there is currently for curves, but I will add it in for the next beta release.
- MIchael
11063.7 In reply to 11063.6
Thanks Michael! I'm looking forward to it.
Pilou: I'll look into having it work for multiple faces at the same time next time I work on this plugin.
- Peer
Show messages: All  1  2-7
