Scripting and Node Editor in Moi3D V5
 1-18  19-28
11061.19 In reply to 11061.18
Hi NaN,
Not quite clear on node groupings, but holding down the shift key while selecting nodes will group them to drag around the screen and select menu options.
Wayne
11061.20 In reply to 11061.13
There is no case for Nodeeditor, I am very interested in Nodeeditor modeling
11061.21 In reply to 11061.20
Hi c3g, there is some information on the node editor here: https://moi3d.com/wiki/nodeeditor
11061.22 In reply to 11061.15
Hi Forum. On Ubuntu using Wine following these directions I'm unable to relocate node editor to "/home/sven/.wine/drive_c/users/sven/AppData/Roaming/Moi" (assuming "I" in original post is a mistake). It does work in "/home/sven/.wine/drive_c/Program Files/MoI 5.0 beta Dec-1-2023/ui". Can sombody confirm this should work as posted ?
Sven
11061.23 In reply to 11061.22
Hi Sven, if you put it in "/home/sven/.wine/drive_c/users/sven/AppData/Roaming/Moi then to launch it you would need this in your shortcut key:
script: moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
If you put it inside /home/sven/.wine/drive_c/Program Files/MoI 5.0 beta Dec-1-2023/ui then the script to launch it is slightly different the URL starts with moi://ui instead of moi://appdata like this:
script: moi.ui.createDialog( 'moi://ui/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
11061.24 In reply to 11061.23
Hi Michael. Confirming your paths and copying & pasting your scripts from your reply it still works via the ui directory, but NOT the appdata directory.
Sven
11061.25 In reply to 11061.24
Hi Sven can you please post the node editor .zip you're using and maybe show a screenshot of where it is installed in appdata?
Thanks, - Michael
11061.26 In reply to 11061.25
Size: 143.3 KB, Downloaded: 157 times, Dimensions: 1920x1200px
11061.27 In reply to 11061.26
Hi Sven, ok so it's because when you're running on Linux/Wine the appdata folder for MoI is at ~/.moi instead. Does it work if you put it there?
11061.28 In reply to 11061.27
Yes Michael. That does the trick, thanks for the clarification.
Sven
Show messages:  1-18  19-28
