Scripting and Node Editor in Moi3D V5
 1-13  14-28
11061.14 In reply to 11061.11
^^Yes, I used the node editor version from James with the recent version of MoI V4. I can retry with the V5 beta when at home again.
Edit: I just installed the Moi3D V5 beta (this time on a M2 Mac instead of a Windows machine) and am getting exactly the same error message when clicking on "Macro".
I placed the uncompressed node editor under "Moi v5 beta Apr-13-2023.app/Resources/ui" and added this start script to the shortcuts: moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
EDITED: 17 Apr 2023 by NAN
11061.15 In reply to 11061.14
Hi NaN, re: Macro error message - looking at the error it kind of looks like the macro code is assuming that the node editor is installed in the appdata folder instead of in the ui folder.
On Mac the appdata folder is at "~/Library/Application Support/Moi", note that the Library folder is hidden by default, you can show it by holding down Shift+Cmd+. (period), or from the menu use Go > Go to Folder
On Windows open the Start menu and type %AppData%\Moi and push Enter, which will expand to something like C:\Users\<Your user name>l\AppData\Roaming\Moi
It's actually generally better to install stuff in the appdata folder since it's a centralized location outside of any one version's app bundle, so new versions will find things there without needing to copy files into each new version's individual .app bundle.
So put it in a folder like: ~/Library/Application Support/Moi/nodeeditor , and then for the launching script on a shortcut key you'll need to have moi://appdata at the start of the URL like this:
script: moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
If that solves it let me know, I'll update the wiki. Probably the wiki install information is from Moi version 3 which was before there was appdata folder support.
EDITED: 17 Apr 2023 by MICHAEL GIBSON
11061.16 In reply to 11061.15
Yay, thanks, that works!
AFAIK, nodeeditor does not have any Group related nodes?
11061.18 In reply to 11061.17
I have been experimenting with "macro" as group. Seems to do the job!
Edit: Oh, you probably mean selecting existing geometry and grouping it via nodes, not grouping nodes? Hm, no idea in that case. (Still only scratching on the surface)
11061.19 In reply to 11061.18
Hi NaN,
Not quite clear on node groupings, but holding down the shift key while selecting nodes will group them to drag around the screen and select menu options.
Wayne
11061.20 In reply to 11061.13
There is no case for Nodeeditor, I am very interested in Nodeeditor modeling
11061.21 In reply to 11061.20
Hi c3g, there is some information on the node editor here: https://moi3d.com/wiki/nodeeditor
11061.22 In reply to 11061.15
Hi Forum. On Ubuntu using Wine following these directions I'm unable to relocate node editor to "/home/sven/.wine/drive_c/users/sven/AppData/Roaming/Moi" (assuming "I" in original post is a mistake). It does work in "/home/sven/.wine/drive_c/Program Files/MoI 5.0 beta Dec-1-2023/ui". Can sombody confirm this should work as posted ?
Sven
11061.23 In reply to 11061.22
Hi Sven, if you put it in "/home/sven/.wine/drive_c/users/sven/AppData/Roaming/Moi then to launch it you would need this in your shortcut key:
If you put it inside /home/sven/.wine/drive_c/Program Files/MoI 5.0 beta Dec-1-2023/ui then the script to launch it is slightly different the URL starts with moi://ui instead of moi://appdata like this:
script: moi.ui.createDialog( 'moi://ui/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
11061.24 In reply to 11061.23
Hi Michael. Confirming your paths and copying & pasting your scripts from your reply it still works via the ui directory, but NOT the appdata directory.
Sven
11061.25 In reply to 11061.24
Hi Sven can you please post the node editor .zip you're using and maybe show a screenshot of where it is installed in appdata?
Thanks, - Michael
11061.26 In reply to 11061.25
Size: 143.3 KB, Downloaded: 157 times, Dimensions: 1920x1200px
11061.27 In reply to 11061.26
Hi Sven, ok so it's because when you're running on Linux/Wine the appdata folder for MoI is at ~/.moi instead. Does it work if you put it there?
11061.28 In reply to 11061.27
Yes Michael. That does the trick, thanks for the clarification.
Sven
Show messages:  1-13  14-28
