Custom command: Select Objects By Type
All  1  2-6
1106.2 In reply to 1106.1
Hi Petr, it works great!
I think that's a nice idea to have it work by following the "example" of the initial single selection, kind of like the priming mechanism for edge or face sub-object selection with window select or select all.
I'd like to add something like this to the regular selection palette for V2, in addition to selection filters. I was previously thinking of having some kind of a menu that popped up a bunch of things like "Select all curves", "select all surfaces", "select all points", etc... But your way shows a good way to potentially combine all those into one thing.
Hmmm, one potential problem though - say you have just the box selected, and now you want to select all curves in addition to that. It won't work for that since it will take the box as the example right away... Probably not a problem for your use but it may interfere with using it as a totally general replacement for separate menu items...
1106.3
Hi, Petr,
Tried out your new script - works great! -- good job :)
Paul
1106.4
Very nice Petr! Thanks!
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
1106.5 In reply to 1106.2
Hmmm... If I linked that custom command to the icon/button, I guess it could be solved. The first click on icon/button would start command as if there was no preselection allowed, it means the command prompt would pop-up and wait for picking an object, but the second click on icon/button would lead to resuming command using pre-selected object - similar to how command Hide works :)
Petr
1106.6 In reply to 1106.5
Hi Petr,
I guess that could solve it, but at that point it seems rather complex compared to a menu with several choices on it...
It's true that it would be similar to Hide, but Hide is kind of a compromise from several different pressures on it, I'm not so sure if it is good to use Hide as a general model to follow.
Since Hide is used frequently it really needed to operate as a top-level button, and I really didn't want to have 3 buttons like "Hide", "Show", and "Show selected", all there at a prominent level, that would just take up too much space.
Selecting objects by type, while certainly useful, just isn't as frequently accessed. So it is not as bad to have stuff for it kind of nested down one level in a sub menu or something like that.
Show messages: All  1  2-6
