V5 beta Apr-13-2023 available now
 1-15  …  56-75  76-95  96-115  116-135  136-155  …  216-223
11056.96
Here's a minor problem where ACIS doesn't work when using the red surface as selection (works with Solid++). ACIS works however if the fillet is applied directly one the 2 circular edges from that surface.
EDITED: 2 Aug 2023 by PAQ
11056.97 In reply to 11056.96
Hi PaQ, thanks for reporting this. Can you please check what v5 beta release you are using? Over here it seems to be working ok with the face selection in the most recent Apr-13-2023 v5 beta release.
11056.98
Unless I am mistaken, variable radius fillets do not currently work with ACIS.
- Zooen
Everything that is imagined and invented is true, you can be perfectly sure of it.
yes variable fillets don't work yet with Acis..
11056.100 In reply to 11056.97
It was with MoI 5.0 beta Apr-13-2023 ... however I can't reproduce it either today in fresh session with that same file, sorry for the false alert :O)
EDIT : actually it wasn't with the last beta ... my bad .
EDITED: 6 May 2023 by PAQ
Size: 20.8 KB, Downloaded: 60 times, Dimensions: 836x48px
11056.101 In reply to 11056.98
Hi Zooen,
They were working in a previous v5 beta, then they got broken in this current beta release and they will be back again for the next beta release.
11056.102 In reply to 11056.101
Thanks for your reply Michael.
I am confident about the evolution of this fantastic 3D MoI with the ACIS system and the next innovations to come.
- Zooen
11056.103
Hi Michael.will moi get something similiar?
extrude by isocurve on solid
https://www.youtube.com/clip/Ugkx60a2fx0LoBB8kTModhLQHR4MxdibLddx
11056.104 In reply to 11056.103
Hi blackboard,
I don't know yet, I have not had a chance yet to dig into the direct modeling functionality in ACIS quite yet.
11056.105
A quick question,
in MOI do we have a command to change normal of the surfaces. ( I have a model when I import it in 123D design in there there are some faces that become invisible, although MOI says it is a solid mesh I think it is because of the normal of the faces.)
-Psygorn
11056.106 In reply to 11056.105
EDITED: 13 May 2023 by PILOU
11056.107 In reply to 11056.105
Hi Psygorn,
There is a Flip command that can reverse the surface normal direction on an open surface:
https://moi3d.com/4.0/docs/moi_command_reference10.htm#flip
But it won't do anything on a closed solid because solids are automatically oriented with normals pointing outwards from the solid volume.
It's more likely that there's some kind of problem in the trimming boundaries of those faces.
It's hard to know what's going on without being able to test with the actual geometry though, can you please post it or e-mail it to me at moi@moi3d.com?
Thanks, - Michael
11056.108
Hi Michael.
I ran into a problem with the Edit Frame when using it to mirror an ellipse. Both need to be tangent to one another for later trimming, so the mirror needs to be accurate.
It seems the correct bounding box dimensions are available in the Edit Size box, but MoI is not using them in this instance. The linked video shows the problem quite well.
https://vimeo.com/826851944?share=copy
Martin.
11056.109 In reply to 11056.108
Hi Martin,
Thanks for reporting this bug, I can repeat it over here and have put it on my list to investigate.
For now to complete your drawing you can use the BoundingBox command followed by Transform > Mirror to get the precise mirrored result.
11056.110 In reply to 11056.109
Thanks for checking this out and thanks for the BoundingBox tip. ;-)
Martin.
11056.111
Hello Michael
The latest version has a feature that interferes a little with the process. This is Alt+Click when executing commands. In general, the problem is that when drawing, say, a circle, with Alt held down (to disable all bindings), a guide is now drawn. And it's incredibly infuriating I climbed everything, tried everything. but I can't turn it off.
11056.112 In reply to 11056.111
Hi blackboard, thanks for reporting that Alt modifier key bug, I'm investigating it.
11056.113
Hey,Michael, can you say pls when will the next beta come out?
Already have an estimated release date?
11056.114 In reply to 11056.113
Hi blackboard,
It will be as soon as I've fixed some bugs I'm working on. I don't know how long that will take, sorry.
Nope.
11056.115
Greetings all.
I don't know if Im missing something, but does Revolve only work with positive angle numbers?
I want to do a 90 deg revolve of a circle to make a kind of elbow shape between 12 O'Clock and 3 O'Clock as shown in green in the attached video,
How do I get MoI to do that without resorting to use Rail Revolve, as -90 deg is ignored by the 'simple' Revolve tool?
Many thanks.
Martin.
https://vimeo.com/828662458?share=copy
Show messages:  1-15  …  36-55  56-75  76-95  96-115  116-135  136-155  156-175  …  216-223
