V5 beta Apr-13-2023 available now
 1-5  …  46-65  66-85  86-105  106-125  126-145  …  206-223
11056.86 In reply to 11056.85
It appears to be all files. Existing ones created in V4 and new ones in V5. If it helps I believe the previous beta, May?, was doing the exact same thing for me as the current one.
11056.87 In reply to 11056.86
Hi crackajack, if you can send me an e-mail at moi@moi3d.com, I can send some v5 test versions for you to try to isolate what change in v5 is causing this compared to v4.
11056.88 In reply to 11056.87
Just an update on this. On my Macbook Pro M1Pro and M2Max setting the ini file GraphicsAPI=Metal was causing the snap issue when display hidden lines is unchecked. I've switched it back to =Auto and everything is functioning correctly. It sounds like Michael is working on what is causing the Metal/Snap issue.
EDITED: 29 Apr 2023 by AKSUV
11056.89
Hi Michael.
Please see the attached video where I discovered a problem after filleting a circular hole. It shows that once filleted, the edges are no longer seen as circles by MoI and also lose their snap points.
Many Thanks.
Martin.
https://vimeo.com/822960972?share=copy
11056.90 In reply to 11056.89
I'm seeing similar problems with ACIS as Martin. In this case I used a circle to Boolean subtract instead if a cylinder, and end up with 2 180 deg. arcs.
The Solids++ version works as expected
Size: 286.8 KB, Downloaded: 172 times, Dimensions: 1637x1341px
11056.91 In reply to 11056.90
Dan, try a G1, G2, or G3 blend - I'm getting the same fault with them.
Martin.
11056.92 In reply to 11056.89
Hi Martin, thanks for reporting this - it should get fixed when I improve the conversion to ACIS to use sphere primitives instead of general NURBS surfaces. At the moment only planes and cylinders get converted to analytic entities in ACIS.
11056.93 In reply to 11056.92
Thanks for that, Michael.
Did you notice my reply to Dan, regarding the fact this fault is also there with G1, G2 and G3 blends?
Martin.
11056.94 In reply to 11056.93
Hi Martin, that's expected for G1/G2/G3 blend modes - those do not generate a torus as the fillet result unlike Circular mode should.
11056.95
It's amazing, I have a problem for constant distance ACIS, but not for circular.
EDITED: 18 Aug 2024 by ZOOEN
11056.96
Here's a minor problem where ACIS doesn't work when using the red surface as selection (works with Solid++). ACIS works however if the fillet is applied directly one the 2 circular edges from that surface.
EDITED: 2 Aug 2023 by PAQ
11056.97 In reply to 11056.96
Hi PaQ, thanks for reporting this. Can you please check what v5 beta release you are using? Over here it seems to be working ok with the face selection in the most recent Apr-13-2023 v5 beta release.
11056.98
Unless I am mistaken, variable radius fillets do not currently work with ACIS.
- Zooen
Everything that is imagined and invented is true, you can be perfectly sure of it.
yes variable fillets don't work yet with Acis..
11056.100 In reply to 11056.97
It was with MoI 5.0 beta Apr-13-2023 ... however I can't reproduce it either today in fresh session with that same file, sorry for the false alert :O)
EDIT : actually it wasn't with the last beta ... my bad .
EDITED: 6 May 2023 by PAQ
Size: 20.8 KB, Downloaded: 60 times, Dimensions: 836x48px
11056.101 In reply to 11056.98
Hi Zooen,
They were working in a previous v5 beta, then they got broken in this current beta release and they will be back again for the next beta release.
11056.102 In reply to 11056.101
Thanks for your reply Michael.
I am confident about the evolution of this fantastic 3D MoI with the ACIS system and the next innovations to come.
- Zooen
11056.103
Hi Michael.will moi get something similiar?
extrude by isocurve on solid
https://www.youtube.com/clip/Ugkx60a2fx0LoBB8kTModhLQHR4MxdibLddx
11056.104 In reply to 11056.103
Hi blackboard,
I don't know yet, I have not had a chance yet to dig into the direct modeling functionality in ACIS quite yet.
11056.105
A quick question,
in MOI do we have a command to change normal of the surfaces. ( I have a model when I import it in 123D design in there there are some faces that become invisible, although MOI says it is a solid mesh I think it is because of the normal of the faces.)
-Psygorn
Show messages:  1-5  …  26-45  46-65  66-85  86-105  106-125  126-145  146-165  …  206-223
